rear spring probs
Old May 4, 2005 | 08:54 PM
Mark1979's Avatar
Mark1979
Default rear spring probs
hi ive just installed my new rear spring i had made buy a freind thatbuilds springs . got it all put back together ...lowerd the car back down and to my suprise it sags worse the the original . im sure i have it back together right ...everything checks out good but im not liking the result ...what would cause this and any ideas on a fix would be great .
Old May 4, 2005 | 09:20 PM
mandm1200's Avatar
mandm1200
Find another friend that knows how to build springs.
Old May 4, 2005 | 09:51 PM
Mark1979's Avatar
Mark1979
lol he does this as a job ...and he is the forman plus the old spring matches up with the new one with a little hieghth added ....in other words the spring is fine and meets the specs perfectly. still confused lol.
Old May 4, 2005 | 09:57 PM
gearheaddroppings's Avatar
gearheaddroppings
St. Jude Donor '05-'06-'07-'08-'09-'10
Are your end bolts on the trailing arms of the longer variety? These will definately lower the car. There are two lengths floating around on the market, so you might want to check.
If not, you might be dealing with some serious problems as the geometry of the frame, etc. might be off.
I betcha its the end bolts on the trailing arms.
Old May 4, 2005 | 11:02 PM
Mark1979's Avatar
Mark1979
not sure but i think the are the short ones but ill check into that thank yu.
Old May 5, 2005 | 09:50 AM
OldSchool's Avatar
OldSchool
Got any pix?
To rear spring probs
