One more bleeding question
Old May 7, 2005 | 07:59 AM
76project's Avatar
76project
Default One more bleeding question
Ok guys, i have a 76 and am sticking with my coffee cup and bleeder hose. I have gone around the car three times, i am getting clear fluid, no bubbles, but my pedal is spongy. I just put in all new metal and rubber lines and new calipers. Did not replace the master cylinder but i did remove and drain it. I remembered I forgot to bench bleed the master cylinder after I had installed everything and started bleeding the system. :o
Do I still need to try to bench bleed the MC? I hate to loosen up lines after I have everything tightend up. I read the post (controversy) about elevating the car in one direction or another.
Thanks for your help...
Old May 7, 2005 | 08:12 AM
stingr69's Avatar
stingr69
Take the M/C off and bench bleed it. Vettes are tough enough even when you follow the directions. No need to make it any harder.
-Mark.
