Hey folks. My 350 build up is progressing nicely. I dropped the motor into the heart of the beast today with as far along as it is. It's basically a long block ready to bolt on the intake and headers.
I waited to this point to order my intake so I can make sure I thoroughly understand my part selection as I go along. My setup is a Comp Cams XE268H, Summit SUM-152123 67cc chambered heads, 165cc runners. What would be a good intake selection that still fits under a stock '77 L48 hood? I'm going with headers on this build up and I'm a little unsure if I need to stay EGR or non-EGR, etc. I plan on using my original Q-jet carb until I find a truly compelling reason to change that over.
I have the RPM Air-Gap with a BG Mighty Demon and a 1/2" spacer that all fits under my stock '77 hood. I do have a K&N drop base air cleaner with a 3" filter element. The drop base air cleaner is mandatory with this set-up.
The only problem might be if you need an adapter to fit your Q-jet on the manifold. I haven't owned a car with a Q-jet in over 20 years...I forgot what they look like.
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i have that same cam and am running a performer intake non EGR with a Speed demon and a 1/2 phenolic space with a drop base airfilter....all fits under the hood no problem.....you will be happy.
