Engine Cut Out, Need Ideas?
Old May 7, 2005 | 10:12 PM
swtato's Avatar
swtato
St. Jude Donor '05
Default Engine Cut Out, Need Ideas?
The last few days my motor has cut out for just a split second and the GEN light wil com on and then it goes back to normal, I even see the tach drop. This literally is a split second.
This afternoon I was turning onto a main highway and shifting into second gear when it did it and it chirped the tires. About a mile late I pulled into the median to turn into my neighborhood and the motor died it would turn over but it was like it was not getting fuel and did not want to fire up. I finally held the gas pedal down while turning the ignition and it started but I had to keep pumping the gas to get it to idle. I was able to drive it normally after that to my house .
Any Ideas on where to start looking for what might be the problem?
These Gremlins drive me crazy!
Old May 7, 2005 | 10:47 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Originally Posted by swtato
The last few days my motor has cut out for just a split second and the GEN light wil com on and then it goes back to normal, I even see the tach drop. This literally is a split second.....
this is not fuel related....its definitely igniton/electrical, start looking at distributor wiring to make sure its ok....could be bad coil, or dwell module.
Old May 7, 2005 | 10:56 PM
SkunkApe's Avatar
SkunkApe
Mine died when the coil got hot. I'd roll to a stop, wait a few seconds and it would start right up. Changed the coil, no further problems...
To Engine Cut Out, Need Ideas?
