crankshaft pulley question
Old May 8, 2005 | 10:43 AM
Sacredgrooves's Avatar
Sacredgrooves
Default crankshaft pulley question
ok-I am trying to eliminate possibilities as to why my alternator belt(only belt on the car) keeps twisting up. my crankshaft pulley seems to have a slightly erratic spin to it(original pulley-69 vette 350)
my first thought is the pulley is somewhat warped,but I am wondering what it attaches to(harmonic balancer?) and can that "something" be causing it to be jumpy? alternator pulley and water pump pulley are fine and smooth. crankshaft pulley is tight. to remove the crankshaft pulley is it just the 3 bolts in the triangular pattern and one in the center and off it comes?
just trying to dig as deep as I can before I buy a pulley I dont need...and learn something in the process.
best way to describe the pulley is a slight shimmy while engine is running and with hood up I can watch the belt as I give the car gas and when I let off I can see the belt producing a wider vibration for a second or so...any thoughts? thanks! Dave
ps- I put on v-belt 15560 duralast after trying several different sizes and have roughly 1/2" deflection measured with straight edge and tape measure and the belt lines up up pretty straight and even with all pulleys(if it is off it is within a 1/8".
Old May 8, 2005 | 10:54 AM
67tripwr's Avatar
67tripwr
I am sure you are aware, that the lower pulley should not shimmy at all.
I have seen many where idiots beat the haromonic balancer on with a sledg! This sometimes causes the pulley to not fit all the way flush to the balancer causing your problem. I have filed and reground these areas and corrected these problems. If this is not the case, that pulley may be bent slitghtly, and would warrant replacment. I would also make super sure all the pulleys line up good!
Old May 8, 2005 | 11:13 AM
Sacredgrooves
maybe I will yank the pulley off and check the balancer for damage.
little more info...ive had the car a couple months and put 1,000 miles on it with no issues. this problem just showed up with nothing changed or worked on beforehand.the belt I put on last night has'nt twisted yet but I havent taken it out of the garage yet either. only tested it sitting still. motor has about 3,000 on the rebuild(along with the rest of the car) but 3 years time since it was restored if that helps at all.
I really should of watched/worked with my dad more when I was younger. he restores muscle cars for personal enjoyment and while ive always loved cars, at that age I had so many other hobbies(guitar,sports,women!!) that I never got very deep into the fixing side. never too late to learn though
Old May 8, 2005 | 11:34 AM
67tripwr's Avatar
67tripwr
Also make dang sure those pulley bolts are all torqued correctly! Good luck
Keep us posted
Old May 8, 2005 | 12:40 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I noticed when I had mine out friday that there are spots that allow for proper installation of the pulleys. They look like a high grommet kinda. I bet that if it isn't installed so those are in the right holes , that you would get a wobble too...
Old May 8, 2005 | 03:36 PM
Sacredgrooves
anyone know by chance what the bolts should be torqued to? I need to buy a torque wrench so now is as good of time as any...
Old May 8, 2005 | 04:04 PM
ZL1powr's Avatar
ZL1powr
One other thing to look for when you check your ballancer pulley, look very closly to see if cracks are radiating out from the bolt holes on the pulley. I have whitnessed this issue on two C3's, a 69 and a 71.
Old May 8, 2005 | 05:09 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Why would someone beat on the balancer with a sledge when it slides right on when heated a bit with a propane torch?
Old May 9, 2005 | 07:36 AM
67tripwr's Avatar
67tripwr
That might be correct in some cases. You can ask any engine builder how many bubba balancer installs he has seen. I have seen them, where they beat on the outter ring, and just ruined them! They are also causing potential bearing damage! Not everybody has a torch, or the proper installation tool. The 427 I just built, I guaranteed a it would laugh at anything but the proper installation tool.
Hey bubba grab me that sledge!
Old May 9, 2005 | 09:07 AM
Sacredgrooves
after talking to my dad about yanking the pulley I think I will get his help. I didnt realize it was torqued to about 150 lbs lol
is a breaker bar the best way to get this off or has someone used another alternative?
Old May 9, 2005 | 10:00 AM
steves_77vette's Avatar
steves_77vette
150 lbs?!?!
The manuals I have all looked at specify 65 ft-lbs. That's Haynes and Vizards rebuild book.
Old May 9, 2005 | 10:40 AM
67tripwr's Avatar
67tripwr
I presume were talking about the center bolt here. I would put it in gear, if you have a 4spd and try the breaker bar. If you can get an impact, this may be better! That bolt is real tough, and you shoul be able to get it out. Some people love to over tighten everything they touch. I remember a lug nut some idiot put on my wifes car. I had to stand on the cheater bar, and finally the stud snapped right off!
Old May 9, 2005 | 09:49 PM
70 MUSL's Avatar
70 MUSL
I am looking at my 69 assembly manual and it calls for the three bolts that hold the pulleys to the balancer to be torqued to 25-35 ft-lbs and the single bolt holding the balancer onto the crank to be at 60-90 ft-lbs. I like to go to the lighter side when using old parts!
Old May 9, 2005 | 11:22 PM
Sacredgrooves
60-90 thats good to know! alot more manageable. have a few worries about using a breaker bar and it smashing my fender if it comes loose lol. my dad has impact wrenches and I plan on getting his help with it this week. it hasnt twisted the belt I have on there now yet,but it is squealing at higher rpm's...
To crankshaft pulley question
