1978 GEN Light question
Old May 8, 2005 | 04:03 PM
78vettman's Avatar
78vettman
Default 1978 GEN Light question
Hey guys,
My interior GEN light came on the other day in my 1978 vette. Where is the best place to start?
Thanks!!!
Old May 8, 2005 | 05:19 PM
matchframe's Avatar
matchframe
The first place I would start is to make sure the belt is still in place. Then I would check the wiring on the back of the alternator.
If all the visual checks look good, I would then use a multi-meter and check the battery with the engine off, then running to see if there is any differences in voltage.
If there is not a difference in voltage, I would pull the alternator and take it to the local auto parts store and have them do a test on it.
After this, it all depends what you find out.
Hope this gets you started in the right direction!
www.bigdogvettes.com
