Brake Pads....Suggestions?
Old May 9, 2005 | 07:55 AM
joes74's Avatar
joes74
Default Brake Pads....Suggestions?
L-48 all stock ......What you reconmmend for a good shoe?
Don't race it...Just cruise
Old May 9, 2005 | 09:41 AM
norvalwilhelm's Avatar
norvalwilhelm
I would strickly use organic pads, they are kind to the rotors and for that one panic stop will match anything. They are not good for repeated panic stops since they fade with heat.
Metalic pads work better hot but eat rotors.
Wagner makes a good organic inexpensive pad sold my most auto parts stores.
Old May 9, 2005 | 10:14 AM
CGGorman's Avatar
CGGorman
For your use, I'd have to agree with Norval.
I'm a brake nut , so I've got Hawk HP Plus pads.
Old May 9, 2005 | 03:04 PM
82Vette'ster's Avatar
82Vette'ster
Originally Posted by norvalwilhelm
I would strickly use organic pads........
For daily driver street car, organic.
Old May 9, 2005 | 03:19 PM
page62's Avatar
page62
Gotta agree with Norval. Organic.
Use the money you'll save for something useful
Old May 9, 2005 | 03:30 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
STOCK,STOCK,STOCK.........
Old May 9, 2005 | 07:21 PM
81corvettevortec's Avatar
81corvettevortec
I like to stop really good. Huge improvement!!!!
Old May 9, 2005 | 08:00 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
How are the organics about brake dust? This is one area of concern for me. I know they all make dust but some are worse than others.
Old May 9, 2005 | 08:03 PM
MEGALADON's Avatar
MEGALADON
I got mine from MAD, they are not that bad!!!!
Old May 9, 2005 | 08:09 PM
Scudd's Avatar
Scudd
Old May 9, 2005 | 09:15 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
semi metallics eat rotors !!! On my daily driver this is ok, the rotors are only $38 each so I usually replace rotors with every second pair of pads and don't worry about it...
On the Vette... I use organic pads to safe the rotors, $14.99 at AutoZone.
Old May 10, 2005 | 12:44 PM
MEGALADON's Avatar
MEGALADON
If you get organtic, you'll be fine. If you don't, this will happen quick.
this is with SEMI METALLIC PADS, from SSBC
Old May 10, 2005 | 04:42 PM
CGGorman's Avatar
CGGorman
Cut rotors (slotted, dimpled, drilled, etc) DRAMATICALLY increase dusting and pad wear.
Old May 10, 2005 | 09:33 PM
stroked75's Avatar
stroked75
Cruising
Go organic you will be satisfied --- I'm sure.
To Brake Pads....Suggestions?
