Quick carb change question
Old May 10, 2005 | 03:01 AM
Kalway's Avatar
Kalway
Default Quick carb change question
I'm going to get a remanufactured q-jet with an electric choke from Summit Racing, soon, for my '81. Do I need to change the distributer, too?
Old May 10, 2005 | 05:55 AM
Pauld's Avatar
Pauld
If you are not going to keep the computer controlled carb, then you will need a new distributor aswell. Also remember that the computer controls the lockup on the TH350. You don't really need the lockup on the gearbox and infact I won't be bothering with it, I will be using mine a just a normal TH350 without lockup.
Old May 10, 2005 | 10:16 AM
Kalway's Avatar
Kalway
I figured as much. I guess I'll have to order one of those, too.
What exactly makes the dist. different on the '81?
Old May 10, 2005 | 10:40 AM
danno12345's Avatar
danno12345
The computer controlled distributor doesn't have the mechanical advance assembly, since the computer can advance the spark by itself.
Have fun!
Dan
To Quick carb change question
