Turbo?
Old May 11, 2005 | 08:57 AM
El_Cid's Avatar
El_Cid
Default Turbo?
I am in the market for a 1979-81. But thats not the point, i was searching aftermarket parts for such vehicles. And well, i was under fiberglass hoods when i came across a "twin turbo" hood. And i was wondering, can one turbo a C3? I had searched google and found nothing but more aftermarket hoods and decal sets, and toyota supra for 30g's. But if you could answer this, that would be great, for i love the whine of turbos. (if there had been a previous thread on this forgive me, cuase i did not find it)
Old May 11, 2005 | 09:35 AM
BrandonS's Avatar
BrandonS
You can turbo just about anything, and this car is no exception. However, there are no kits available, and i don't believe there are any turbo manifolds out their either. You'll need a good welder/fabricator to make you two manifolds, and then a good tuner to part together a turbo kit. I have no idea what it would cost. You'd be better of SC'ing in my opinion, and could go with one of those under the hood kits. Its crammed with the vette and needs to be modified, but i've seen it work before.
Old May 11, 2005 | 09:43 AM
gkull's Avatar
gkull
F.A.S.T. out of the chicago area builds them. By the time it's all said and done your looking at @ $15,000 USD if you already have a very stong motor and tranny to build on to.
The big cost is the custom miniram type sequential fuel injection system the sensors and electronics. That's about $8000 of the cost. The rest is the custom all stainless headers, intercoolers and plumbing.
Old May 12, 2005 | 12:18 AM
Russ Bellinis's Avatar
Russ Bellinis
If you live in Ca. you can't turbo it and get past the smog *****.
Old May 12, 2005 | 12:51 AM
lostpatrolman's Avatar
lostpatrolman
There are actually a few people that have turboed their c3s.
Montys old car - http://www.montygwilliams.com/
Saku's TT - http://www.rmotorsport.com/2003/?sx=en.corvette
Twin turbo has twin turbos, go figure..
There is also some new member that has twins, forgot his name though.
All of these guys went with twins, but it would be just as easy to go single. You would have to do something like this though.
Old May 12, 2005 | 01:01 AM
lostpatrolman
Just searched adn found the other guy
my72vette454
He had some pics posted here, but they seem to have disappeared
http://forums.corvetteforum.com/show...rbo&forum_id=3
Old May 12, 2005 | 01:03 AM
Solid LT1's Avatar
Solid LT1
Gale Banks will be more than happy to set you up with one of their "crate" turbo motors. Banks is one of the best in the business. Here is a link: http://www.bankspower.com/twin-turbo-engine.cfm
Old May 12, 2005 | 08:35 AM
El_Cid's Avatar
El_Cid
I live in auburn hills, where they worship any handy-man work on one of the big 3's cars. But thanks for the answer. I think it would be just a litle sweeter to have a turbo.
But just for the record, how much would a supercharger cost (and how much to install?)
Old May 12, 2005 | 08:37 AM
Twin_Turbo's Avatar
Twin_Turbo
The banks stuff does not fit because of the position of the waste gates, they interfere with the upper control arms.
Old May 12, 2005 | 10:55 AM
gkull's Avatar
gkull
Look back in the engine mod section and this guy installed a $3500 whipple charger and another $3500 in the FI and you can also have a 700-800 hp motor.
Old May 12, 2005 | 12:16 PM
toddalin's Avatar
toddalin
Find an older Martin set-up for a Corvette. This was a draw-though system using the stock carb that fit the Vettes with stock hoods. One of our club members has one on his '78. He reports about a 50% power gain. I would think that with a modern impeller design, even high boost levels could be attained.
Old May 12, 2005 | 12:36 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
You can also do a setup similar to the STS system (http://www.ststurbo.com/). This was something I was considering before deciding to go back to school. It wouldn't be that hard to do with minimal farication expense.
Here's what the turbo looked like mounted to my car.
To Turbo?
