Courtesy Light Question
Old May 12, 2005 | 05:58 AM
Randy2red's Avatar
Randy2red
Default Courtesy Light Question
I found the kick panel courtesy lights in my 1980 corvette inoperative & dangeling. I replaced bulbs & now working but can not figure out where they were mounted. Can anyone help?
Old May 12, 2005 | 08:27 AM
texaswilkins's Avatar
texaswilkins
The left side is a plastic holder that clips into a small slot in the dash belwo the speedo. You have to crawl under and use a mirror to find it. Right side mounts to the top of the kick panel. There should be a rivet hole in the top of the panel where a small metal L bracket holds it on. That's how my 78 was. If your 80 doesn't have that bracket look for a slot in the dash like on the drivers side.
Bill
