Front Crossmember Bolt Size
Old May 13, 2005 | 11:07 AM
Golden's Avatar
Golden
Default Front Crossmember Bolt Size
Hi guys, I'm replacing the front crossmember on my '71 and want to replace the bolts.
Could someone tell me what size I need, thanks guys.
Old May 14, 2005 | 05:59 AM
Golden's Avatar
Golden
Come on guys, I'm just a metric idiot
Old May 15, 2005 | 09:28 PM
68/70Vette's Avatar
68/70Vette
I was a little surprised that no one answered your question,expecially because for some it would be very easy to answer. Anyhow, I went out and unscrewed one of the bolts in the crossmember you asked about. The bolts are 7/16 NC 14. This means the bolt thread diameter is 7/16 and the bolt is a "course" bolt with 14 threads per inch. Using my caliper, the threaded portion of the bolt is 1.25 inches. So I think you want to order 1 1/4 inch 7/16 NC 14 bolts. You also should order a lock washer and a plane washer. Socket size: Even though the treads are 7/16 inch, you will need a 5/8 inch socket to tighten the bolts.
This English/metric thing really annoys me. Up until 1975 (or so) probably 80% of all the nuts and bolts ever made by mankind were "English" threads. I wonder if we've had to go through this grief of changing nut/bolt standards because the basic measuring system was labelled "English."
Anyhow, I have a lot of metric tools. For the tool manfacturers it's a good business because people like me have to buy two tool sets instead of one.
Old May 16, 2005 | 12:32 AM
glen242's Avatar
glen242
Back in the "old days" my '59 TR3 used English bolts. Wentworth I believe.
American bolts were SAE, German and other European were metric.
Old May 16, 2005 | 10:49 AM
Golden's Avatar
Golden
You Sir, are a real gentleman! Cheers, really appriciate it
To Front Crossmember Bolt Size
