80 A/c ?
Old May 13, 2005 | 01:18 PM
Hvymtlc5's Avatar
Hvymtlc5
Default 80 A/c ?
On the 80 A/C system..which is the "low" side...the fitting by the compressor or the one back by the big aluminum thing (condensor?) close to the fire wall and heater core box?
Yep - you guessed it - I don't know anything about A/C
Old May 13, 2005 | 01:21 PM
Hvymtlc5's Avatar
Hvymtlc5
Been told that the big silver thing is an "accumulator"?
Old May 13, 2005 | 01:32 PM
PhotoVette1's Avatar
PhotoVette1
They both are. The high side is by the right wheel-well and is attached to the siteglass.
Old May 13, 2005 | 01:35 PM
Hvymtlc5's Avatar
Hvymtlc5
Where does the refrigerant go in?
Old May 13, 2005 | 01:44 PM
Hvymtlc5's Avatar
Hvymtlc5
Please confirm that I have this right. To add refrigerent, I'll add at the line fitting tap that is coming from the evaporator (low side) to the compressor? The line into the evaporator, leaving the compressor is the high side?
Old May 13, 2005 | 02:56 PM
kevinator80's Avatar
kevinator80
Add freon to the ports connected to the big lines. The small lines are high pressure.
Old May 13, 2005 | 08:17 PM
PhotoVette1
The one on the compressor is the easiest to get to.
Old May 13, 2005 | 09:14 PM
DonBecker's Avatar
DonBecker
DO NOT hook up the filler hose to the high side.
The can of refrigerant will turn into a grenade.
When in doubt, ask more questions...
Old May 13, 2005 | 10:18 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
The large line is the low-pressure side. The fitting on the low-pressure line is larger than the fitting on the high-pressure side.
Neal
Old May 14, 2005 | 07:47 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Just in case.... since you said you don't know much about AC are you sure you have the right TYPE of refridgerant? The 80 does not use the 134A that you may very well have bought at AutoZone without converting the system....
Old May 19, 2005 | 03:00 PM
Hvymtlc5's Avatar
Hvymtlc5
I had some R12. You guys made it simple by pointing out the big line is low pressure and small is high...charged and blowing cold.
To 80 A/c ?
