Radiator Core Size
Old May 13, 2005 | 06:00 PM
vetteboy1976kr's Avatar
vetteboy1976kr
Default Radiator Core Size
How do you determine the "core size" on a radiator? The 76 had two different sizes: 26" & 27". Do you just measure the radiator across (from tank to tank) and that is the size? Surely it can't be that simple
Old May 14, 2005 | 10:13 PM
glen242's Avatar
glen242
Where did you get your information concerning rad size?? According to my GM info, the rads were the same width. The L82 and AC cars used a 4 tube core rather than the base 3 tube core and held .5 Qt. more liquid. I had my '76 recored with a 4 tube core. Dimension between the intermost surfaces of the top mounting brackets is 27", this is the size of the core.
The simple part is - GETTING THE RIGHT DIMENSIONS, to start with. I am using my GM 1976 Corvette Specifications manual, available, still I think, direct from GM at no cost.
Old May 19, 2005 | 12:08 PM
vetteboy1976kr
The dimesion difference is that one is early 76 and the other is late. I have a late car with the correct radiator support, but am trying to determine if I have the correct upper brackets and radiator (they don't seem to fit right). I have the early brackets (without shroud mount holes) and a radiator from Zip. Thanks for the dimension.
Old May 19, 2005 | 12:53 PM
mandm1200's Avatar
mandm1200
Another difference with the late 76, same as the 77, is the location of connectors for the automatic tranmission cooler. The later model also has a diiferent upper hose connector.
To Radiator Core Size
