What does this do???
Old May 13, 2005 | 08:37 PM
Jclgodale3's Avatar
Jclgodale3
Default What does this do???
Ok...this bracket is on both sides of my VBP fiberglass rear spring. What is it's purpose? It is obviously adjustable in 4 different holes but what do you achieve with these adjustments? Thanks for any input!!
Old May 13, 2005 | 08:54 PM
jpatrick636's Avatar
jpatrick636
I believe you can change the spring rate by mounting inward or outward.
Old May 13, 2005 | 11:13 PM
Jclgodale3's Avatar
Jclgodale3
any idea which is which? stiffer as it goes out? More spring? Does it change ride height? Anyone else?
Old May 13, 2005 | 11:33 PM
2002z28ssconv's Avatar
2002z28ssconv
Outward will be softer and might lower the ride height.
Old May 14, 2005 | 09:04 AM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
Moving from one hole to the next will change your spring rate. Going out (towards the wheels) will increase the spring rate. Towards the center of the car is softer.
Old May 14, 2005 | 02:07 PM
Z-man's Avatar
Z-man
Toward the center is softer, outward is stiffer...
To What does this do???
