Oil in intake manifold
All the plugs look about the same, a little bit of black deposits on the ground electrodes, except #2 and #3 are pretty clean (fed by the same runner). All the head ports have a little oil in them, also except #2 and #3. There was a little oil around #6 and #7 port on the manifold, but I don't know if it was from running or it dripped out of the heat shield.
I'm bringing the manifold to my machinist friend, he's going to give it a good looking-over. Another set of eyes might catch something. I am giving him the old gaskets, the RTV off the ends and I didn't wipe anything, so he can play detective with as many clues as possible.
Hopefully he'll find something, and/or gasketdude will come up with a miracle gasket. BTW, the steel-core NAPA gaskets I used measure under 1/16" compressed.
Joe
PS, can't try "the test" now, but it sounds like a good idea if I still have problems.
[oh yeah, I looked at the bolt holes real carefully before I unstuck the manifold. They all looked perfectly centered. Was the original GM head gasket a steel shim in 1973? ]
Will try sealant around ports. Tossing up between non hardening Permatex or black silastic. Permatex would last longer but the silastic will fill a bigger gap. Contact glues have also been mentioned but they are a little harder to use properly.
I did have this problem years ago when I swapped intakes from an Edelbrock Performer to a LT-1 copy intake. The new intake was machined wrong and it never would seal right. The car ran stronger with the new intake but it was not sealing at the ports. After several tries at regasketing and still having the problems I gave up and went back to my Edelbrock Performer. I also added a Moroso valley pan baffle to keep the oil splash off the bottom of the intake surfaces. Not a bad mod if you ask me. The power was down a bit with the Performer intake but the problem went away.
-Mark.
THAT finally cured the oil sucking problem....the gaskets were wet and it looked just like the pictures....oil stains all over the bottom 1/2 of the gaskets...and yes, I also have some oil in the PCV problems also....stock valve covers, but I cured most of that....
GENE
GENE
Thinking I should pull the front/rear cork strips and use RTV if (and ONLY IF) they are in fact contributing to the intake/head sealing problem...
FWIW, I JUST installed the Printoseals a weekend ago and am checking the oil periodically to see if I have solved my consumption problem on the '80 L48. Definitely have less 'lifter noise' (was another problem I was diagnosing. I suspect the lifter noise was actually noise coming from the leaking intake gasket. Quieter now but not completely gone...
There's nothing wrong with the intake manifold or the gaskets. They are all compressed equally and line up with the ports.
That means something else is causing the oil leakage: either valve seals or I installed a second piston ring upside down.
The seals are hard plastic, could be a problem, but nobody else seems to have problems with these heads. I don't want to tear the motor apart either. So I'll change the seals and hope for the best.
It seems odd that oil could go by the rings and back up to the manifold, but he says reversion does funny things.
Joe
I removed the Torker II that I installed last week with great care. I did everything by the book and then some.
- Used FelPro 1212's that will compress - not hard like the 1210's were.
- Use Edelbrock Gasketcinch on the head and gasket as a contact cement and boy did it hold the gasket in place.
- Used RTV Red on the end rails, not the rubber ends.
- Torqued the maniofld bolts not once but 3 times letting it set for about 12 hours each time.
Results - after about 10 minutes of run time the damn thing was smoking again. Me too!!
- Pulled the carb and the floor of the manifold was oily.
- Pulled the manifold and the print of the manifold to the gasket seemed ok to me, not off center etc.
- All and repeat all runners were oily in the manifold.
At this point I do not think it is the intake manifold sealing, but rather something else feeding the oil into the manifold, but I do not have a clue what it would be. I can't believe all 8 intake guides are messed up as they were new with only 300 miles on them and used PC seals.
This has happened with 2 different stock intake manifolds. The heads are the 1973 049's and I do not believe the intake rocker studs are open to the runners as were some older ones. I can not feel them protruding or open into the runner. I have heard this is a problem on some and needs thread sealer. Am I missing something in this area??
I used a new Delco fuel pump on the rebuild so I would doubt the thing is sucking oil, but at this point who knows. I did not see oil residue on the carb filter.
The PCV valve is a possibilty but I changed this with others also. I plan on putting on another manifold that I have - Pro Products cyclone that I am borrowing from a shop. At that time I will pull and block the PCV valve to see what happens.
The trans vacuum line to the modulator is a possiblilty but I am not losing fluid and the oily residue in the intake is not red.
Question - How can I tell if the heads are not of the correct angle on the intake ports and no manifold will ever seal?
Compression check or leak down or pray - advice.
Thanks for reading this problem. Jim
-Mark.
After I install the intake I am going to pull the rockers and put in unbrealla seals a matter of fact. Yes, the PC seals are new but who knows if there are any good. Thanks for the advice.
Jim
Do not use the front and rear gasket strips. Only use RTV in that position. Use some High-Tack on the gaskets around the port openings on both sides of the gasket. High-Tack is rated for gasoline contact. Many other sealers are not rated for continuous gasoline contact.
It IS coming from somewhere.
Maybe the fuel pump diaphram is leaking?
-Mark.
Use nothing front and rear. You want to check for any contact across the front or rear block/intake interface with the manifold torqued down. Normaly, the front and rear interface on the block/intake surface has a gap that we fill with RTV sealer. If the machining on the block/heads/intake is off a bit, the intake could bottom out on the top of the block front or rear surface causing the ports on the side to be up off the heads a tiny bit causing a leak. Run a feeler gauge across the front and back to be sure you have a gap. Not a likely problem but one you need to check. As for the umbrella seals, I would pull the other seals off and try running with just the outer springs and the umbrellas in an effort to diagnose the situation. Be sure to wiggle the valve stems while you have it apart to check for excessive clearance. If the situation improves, you are getting warmer.
-Mark.
I haven't started troubleshooting the problem yet. It's the original block, so it could be rings. Or it could be the intake sucking oil.
I don't have the telltale blue smoke on startup caused by bad valve seals, so I don't think that's it.
Stay tuned...
