LT-1 Exhaust question
Old May 14, 2005 | 04:22 PM
yellow71's Avatar
yellow71
Default LT-1 Exhaust question
I have a 71 LT-1 with round mufflers installed by PO. Would like to replace with stock looking aluminized system. Here is my question - all the books say the LT1 has a 2 1/2 inch exhaust. Where is this measured? The width of the pipes on the car now are 2" in diameter from the exhaust manifold all the way back. Does this mean I should also order 2 1/2" pipes and mufflers as well? How can I check to make sure a 2 1/2" system will fit on my ehaust manifold? Trying to sort this out BEFORE ordering so I don't have to return ship everything.
Thanks for any tips
Neil
Old May 14, 2005 | 05:39 PM
Gordonm's Avatar
Gordonm
The LT1s used the same exhaust manifolds as the other Vettes. The pipes actually go from 2 inch to 2 1/2 inch about 5 inches after the exhaust manifold. It stays 2 1/2 back to the muffler then exits the stock muffler at 2 inches. To me the exhaust manifolds and head pipes are way to restrictive. My LT1 would really lose power above 5000 rpm. I was amazed at what a set of headers did. Reved quite easily to 6500. I them had a custom 2 1/2 system with Flowmasters and it gained 4 mph and 3 tenths in the 1/4 mile. Huge difference in seat of the pants feel also. My opinion is the LT1 stock exhaust is no better than the stock 2 inch system. If you are looking for more HP ditch the stock system and get a custom system with headers and 2 1/2 pipes and a set of good mufflers. If you are into stock looking then get the stock 2 1/2 system.
I have actually measured the inside of the pipe as soon as it leaves the exhaust manifold. It is 1 7/8 diameter. Very small. I know of some big inch high HP small blocks running 1 7/8 primary pipes on the headers. A lot of HP is gained by going to a set of headers.
Old May 14, 2005 | 05:41 PM
dennis's Avatar
dennis
exhaust manifold is 2" out to the short exhaust pipe. Short pipe is 2" top side,(where it connects to the cast iron exhaust manifold), and 2 1/2" at the lower end where it connects at the trans mount to the long pipes. The long pipe is 2 1/2" at the front connecting to the short pipe and 2 1/2" at the rear where it connects to the front of the muffler. The muffler is 2 1/2" at the front and 2" at the rear where the chrome square tips connect.
Side note: Some venders supply the long pipe that is round the whole length. The original long pipe was somewhat flattened along the mid-length where it's closest to the ground for the obvious reason. Either one will work. Some people think the rounded one is less restrictive, although it's not correct.
Old May 16, 2005 | 09:27 AM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Default LT-1 Exhaust System
Neil,
Unfortunately, there are no vendors accurately reproducing the LT-1 exhaust system. If it were me, I'd take a look at Allen's as they make a quality system that fits well even if the accuracy of construction is a bit off.
Several years ago, I came into possession of a real LT-1 exhaust system that was taken off of a 1970 LT-1 when it was new (8 miles on the odometer I was told). I posted photos and descriptions of this exhaust system in a previous post.
http://forums.corvetteforum.com/show...um_id=3&arch=1
I'm am told that the rear pipes and mufflers are the same for 1970-1972 big block Corvettes as well.
Regards,
Old May 16, 2005 | 09:41 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Stan-cool pics-just went over them again for my own knowledge
Old May 16, 2005 | 10:21 AM
Gordonm's Avatar
Gordonm
Great pictures but it just shows how restrictive the pipes are. You could free up quite a few HP by headers and a good system.
That is a nice reference for the NCRS guys.
Old May 16, 2005 | 10:40 AM
Paul Borowski
Old May 16, 2005 | 12:26 PM
Rowdy Rat's Avatar
Rowdy Rat
Paul,
The guy I bought them from has some very cool parts that he's not ready to part with yet... But I always let him know that he can count on me to take them off his hands if he ever changes his mind. He swore he'd never sell his LS-6, but that ended up in my garage a couple years ago... So I guess there's hope!
Great guy... Former Bloomington Gold judge and a great body/paint man. He did the paint on my current LT-1 and will paint the LS-6 as well when I get started on it.
Gordon,
True, the exhaust is not as efficient as tubular headers and low restriction mufflers... No doubt that the stock system is giving away a few horsepower there. For the street though it is sufficient and certainly a lot quieter... Something that GM had to deal with when the cars were new.
Nice autocross photos! I used to run a 1983 Volkswagen GTI in ES and DSP as well as 1991 and 1992 Corvettes in SS... Great fun!
Regards,
Stan Falenski
Old May 16, 2005 | 01:21 PM
Kid Vette's Avatar
Kid Vette
Here's some pics of a restored LT-1 with, what I believe to be the original exhaust. It was sold on Ebay a couple years ago.
Old May 16, 2005 | 04:31 PM
Rowdy Rat's Avatar
Rowdy Rat
Mark,
The pipes themselves look pretty darn good... They could be production pieces or early service replacements as there are no major differences between the two. The texture on the pipes (there appears to be some minor pitting) leads me to believe that they have had some rust on them at one time and were sandblasted to clean them up.
The mufflers (at least the one where the writing is visible) have "GM" and a part number embossed on the casing... This is typical of a service replacement muffler. The originals carry a "W" without any part number or "GM" identification. In fairness, the mufflers almost always rust before the pipes so this is to be expected. It would be interesting to see if the rear of the muffler had a second mounting bracket at one time (which is also a characteristic of service replacement mufflers).
In any case, this is a very nice setup... If the work on the chassis is any indication as to the quality of the rest of the car, it alomst certainly looked fantastic!
Regards,
Stan Falenski
To LT-1 Exhaust question
