First Real Problem with new vette
Old May 14, 2005 | 10:00 PM
vette70's Avatar
vette70
Default First Real Problem with new vette
I have a eldelbrock carb and 350/350. Ran fine came home as I pulled into driveway and let off gas it died. Now very hard to move the vette without reving high and let clutch out slow or dies instantly. If I slowly bring rpms up to about a 1500 I can then rev. engine but if idiling and try to bring rpms up fast it coughs. Any ideas
Old May 14, 2005 | 10:37 PM
FB#1's Avatar
FB#1
Check the hose coming into the base of the carb for any cracks at the bends. Possibly a split/cracked vacuum hose.
Old May 15, 2005 | 01:26 AM
Sharky Guam's Avatar
Sharky Guam
yep, sounds like a vacuum leak somewhere....
Old May 15, 2005 | 07:11 AM
BigBlockk's Avatar
BigBlockk
Does it sit and idle ok? A vacuum leak is most troublesome at idle. You say you can't pop the throttle open quickly. This is an accelerator pump problem. May want to call the Edelbrock help line.
BigBlockk
Later.....
Old May 15, 2005 | 07:21 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Sounds almost identical to the symptoms I experienced on my initial drive home. I wrote a depiction at my site too. Looking back it seems almost funny now.
I took it to my mechanic and he said the carb need to be rebuilt. He said that would be $3-400!!
I ended up buying a new Edelbrock for about $200. Problem solved. Since that day, I've been doing everything myself.
To First Real Problem with new vette
