Q-jet Base plate's
Old May 15, 2005 | 02:34 PM
comp's Avatar
comp
Default Q-jet Base plate's
looking to swap part's between carb's,,, what are the difference's i need to watch for ??? Thanks
Old May 16, 2005 | 12:23 AM
comp's Avatar
comp
nobody ????
Old May 16, 2005 | 02:45 PM
comp's Avatar
comp
i must ask the hard question's
Old May 17, 2005 | 12:23 AM
comp's Avatar
comp
Dammmmmm i guess i'll tare 4 or 5 apart and try them
Old May 17, 2005 | 09:33 AM
comp's Avatar
comp
got one set of sec. throttle blade's
Old May 18, 2005 | 09:11 AM
comp's Avatar
comp
tore apart 3 carb's ,,look the same ANYBODY got the spec's for the throttle shaft's and bore's ???? don't see in any of my book's
Old May 18, 2005 | 09:26 AM
isosceles's Avatar
isosceles
wish I could help.
try PM'ing Lars.
Old May 18, 2005 | 09:35 AM
comp's Avatar
comp
i'm sure he has alot going on ,,someone should have spec's
Old May 18, 2005 | 12:22 PM
Maymyvetteliveforevr's Avatar
Where not ignoring you, we just don't have the answers you'd like to hear.
Sorry!
Old May 18, 2005 | 12:27 PM
ksbunting's Avatar
ksbunting
Lars would be the only one I would feel totally comfortable with as regards the answers to this question since he is the expert.
Old May 18, 2005 | 02:52 PM
comp's Avatar
comp
Sorry!
i just seam to allways ask the Hard question's
Old May 18, 2005 | 02:54 PM
comp's Avatar
comp
true, but i know he's got ton's to do,,, from what i can tell the base's are the same,,, still not sure what shaft's and bore's should measure,
still have a few to tare apart
Old May 18, 2005 | 11:46 PM
comp's Avatar
comp
one base is probably going to be found rust in the shaft's....the more i dig the more crap i find
Old May 19, 2005 | 12:20 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
The base plates are similar from 70-74. I believe all these have the brake booster nipple in the rear, unlike previous years. It's easily plugged with a threaded plug if you wish.
Stay away from 68-69 base plates. In these years, exhaust gas was routed through the intake to heat the carb for warm up and reduced emissions. A thin "heat shield" was sandwiched between two gaskets, but it was bad design...in fact Chevy had several service bulletins and maybe even a recall in 69. Turns out 8-900 degree heat isn't good parts made of pot metal (though the base is alum). Regardless, there are a lot of 'service' carbs with 68-69 dates out there.
I've heard to stay away from Carter-built Q-Jets, but I've never read anything credible that defends this theory.
Lastly,..you want nothing to do with smogger Q-Jets (1975+). These are stamped "7045XXX" or higher numerically. The range of tune is lost, even on the idle mixture screws which are in the base plates.
Good base plates are easier to find than good choke horns, which are the softer metal, and have suffered years of over-tightening which causes them to "bow" in the front which leads to metering and vacuum probs.
You might pick up the book "Rochester Carburtors" by Doug Roe...great guide!
Good luck,
Wes
Old May 19, 2005 | 12:31 AM
comp's Avatar
comp
Good luck,
Wes
thanks ,,have the book... good base plate's are EZ to find ???? not so far here in my pile that why i need the spec's on the shaft's I may be able to save 1 or 2 for a good DD or better
Old May 19, 2005 | 08:13 PM
73, Dark Blue 454
The specs on the shafts never changed. It'd be nice to find a base plate that didn't need trottle shaft bushings...semi difficult job and you'll need to find some butterfly screws to reattach the butterflies.
Here's my favorite place for q-jet parts...great guys to work with and prices are pretty good:
www.weber-carburetors.com
They'll have what you're looking for.
Good luck,
Wes
Old May 20, 2005 | 10:20 AM
comp's Avatar
comp
cool they didn't change so what are they thanks for the link
To Q-jet Base plate's
Old May 20, 2005 | 06:12 PM
comp's Avatar
comp
still haven't found in my book's
Old May 23, 2005 | 12:18 AM
comp's Avatar
comp
ttt
Old May 24, 2005 | 01:45 AM
comp's Avatar
comp
anybody got one they can measure ????
