Headlamp vacuum leak
Old May 15, 2005 | 03:58 PM
Pauld's Avatar
Pauld
Default Headlamp vacuum leak
Well I ahve just sucessfully completed my head, cam, intake and carb change and have the engine running pretty good with a nice idle.
The only problem is that now only one headlight comes up (the passenger side one) and the other doesn't come up.
Where is a good place to start to find it, is there anything obvious that anyone can tell me?
Old May 15, 2005 | 04:39 PM
brooksman9's Avatar
brooksman9
St. Jude Contributor
Don't have an answer to your question, but glad to see you got everything swaped out ok. Like to hear more about it when you get a chance.
Old May 15, 2005 | 05:00 PM
Pauld's Avatar
Pauld
Will do, I will also post some more during and some after pics. Everything went pretty well, I haven't driven it yet since I need to adjust the throttle cable but it runs vert nice. Just need to sort out a leak od transmission fluid from one of the radiator connections and I will be done.
Old May 15, 2005 | 07:38 PM
Duke94's Avatar
Duke94
Check the vacuum lines at the actuator as well as at the vacuum tank (hollow front crossmember)
Old May 16, 2005 | 03:10 AM
Pauld's Avatar
Pauld
I will check those thanks . I was thinking that it must me something that I had pulled off the carband the old emission system because everything else I hadn't touched.
Old May 16, 2005 | 06:51 AM
Graemeinvette's Avatar
Graemeinvette
Just a wee tip while you are looking at your vacum hoses, if any of them are a bit loose put some rubber solution on the metal nozzle and slide the hose over. It should eliminate any minor vacum leaks and it doesnt have too much grip that you cant take them off again if you need to.
Graeme
Old May 16, 2005 | 12:20 PM
Pauld's Avatar
Pauld
Graeme
Thanks Graeme
Old May 16, 2005 | 12:39 PM
terry82's Avatar
terry82
go to corvette 101 [google search ]then go to the left find vac trouble .
Old May 16, 2005 | 01:06 PM
Pauld's Avatar
Pauld
That's a great site Terry, thanks alot, just the sort of information I was looking for
To Headlamp vacuum leak
