brakes....
Old May 15, 2005 | 04:04 PM
onaqwst's Avatar
onaqwst
Default brakes....
i have new calipers and a new master cylinder also new braided lines.... i still can't get a pedal.... it's spongy and won't stop until all the way down.... any ideas..... lines don't have any air....good bleeds...
b
Old May 15, 2005 | 04:07 PM
stingraymaniac's Avatar
stingraymaniac
Did you bench bleed the master cylinder?
Old May 15, 2005 | 05:06 PM
onaqwst's Avatar
onaqwst
yup...bleed the mc b4 install...... i put in a new cam and still need to fully adjust the timing and rockers...u think i could be losing vacuum there.... i'm not really sure.....
b
Old May 15, 2005 | 05:11 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
I just did mine yesterday and I'm amazed at how long it took me to get a pedal out of it.
I bench bled the master too, and used my vacuum bleeder on all four rear bleeder valves. When I started to get fluid outta the right rear outer, I moved to the right rear inner, and same with left side. No pedal yet so I did it again. Burned right thru a whole quart of fluid then, only to get a very poor at best, pedal out of it.
Started again with the RRO bleeder, and waited til I had a good solid shot out of it, then on to the RRI bleeder. Same with LRO then LRI and now it has a great feel to the brakes. Best since owning the car.
PS on mine, I had done the front calipers last summer, and yesterday I did the rears along with a new master.
Old May 15, 2005 | 05:45 PM
Matt Gruber's Avatar
Matt Gruber
http://community.webtv.net/MATTGRU/BRAKES
Old May 15, 2005 | 08:02 PM
onaqwst's Avatar
onaqwst
i'll try the alien technique.......
thanks
b
Old May 15, 2005 | 09:34 PM
Empatho's Avatar
Empatho
I didnt drive my car for a month and all of a sudden the brake pedal feel's spongy I dont know why the brakes were great before and know it feels spongy and sometimes the brake light on the dash comes on does any one know whats wrong
Old May 15, 2005 | 11:06 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
bleeding is a subject with so many different opinions and preferences..... I never did it before and I got perfect results with my "home depot presure bleeder"... it was a 30 minute job.... pressureize the system with a garden sprayer (bug poison sprayer) which is filled with brake fluid, bleed the sytem - careful, you'll get pretty high flow - and be done with it....
others prefer vacuum bleeding, others prefer gravity bleeding.... all of this works fine if done right.... be patient....
Old May 16, 2005 | 12:47 AM
Z-man's Avatar
Z-man
Sounds like one of your calipers has a leak...
To brakes....
