Installing rear spring bolts
Old May 15, 2005 | 05:06 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Installing rear spring bolts
I installed the new 8" spring bolts yesterday and I've got a couple of questions:
First, why are they NOT cross-drilled for a cotter pin? Second, can the Nyloc nuts be backed off, once they are in position?
Reason is that I ran the nuts up about an inch or so on each side, and the car didn't drop more than a quarter inch or so. I would love to back those nuts off to the end of the 8 inch bolt, if I was sure I could trust them. They are VBP bolts and nuts.
Bottom line -- is it safe to just back those nuts off toward the end of the bolts?
Old May 15, 2005 | 05:37 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
I was thinking the same thing, so I drilled holes in mine when I had the height set and used the castle nut and cotter pin.
Old May 15, 2005 | 06:07 PM
BerniesVette's Avatar
BerniesVette
Twenty year old technology said you use them only once. Does that include backing them off a little. I would drill them, as stated earlier, and put castle nuts and cotter keys back. Always err towards safety!
Bernie
Old May 15, 2005 | 06:16 PM
mandm1200's Avatar
mandm1200
Although it's not the answer you wanted to hear, you could muchroom the bottom of the bolts a little. That way if the nuts did back off the wouldn't come off the end of the bolt. It would make it more difficult to remove later.
Old May 15, 2005 | 06:38 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I believe I would let them down and see if that is where I want them to be. If that is it, just go to Home Depot, Lowes, or Ace Hardware and get new nuts.
Old May 15, 2005 | 06:43 PM
Hitch's Avatar
Hitch
Backing them off will not destroy them.. I would NOT dimple the ends of the bolts... If you feel that unsafe remove the bolts drill a hole and insert a cotter pin. They will be fine though... Dave...
Old May 15, 2005 | 07:57 PM
mandm1200's Avatar
mandm1200
Originally Posted by Eddie 70
and get new nuts.
And get some for the bolts as well.
Old May 15, 2005 | 11:02 PM
SanDiegoPaul
Arruh?
Old May 15, 2005 | 11:13 PM
redvetracr's Avatar
redvetracr
Your bolts are not drilled because they are from VBP and NOT from GM for a Corvette, they are generic bolts you could of bought for (probably) 1/2 price and NO shipping from any industrial supply. I have longer bolts, loctite (blue) and double nuts holding mine together.
...redvetracr
Old May 15, 2005 | 11:14 PM
Jclgodale3's Avatar
Jclgodale3
...redvetracr
Old May 16, 2005 | 12:52 AM
SanDiegoPaul
Originally Posted by Jclgodale3
That makes sense. I want to drop the rear another half inch and since LockTite has worked for me in so many other ways, I'll do the double-nut and LockTite thing with this project. Thanks Guys ....
Old May 16, 2005 | 02:48 PM
Timbo2's Avatar
Timbo2
Default lowering stance...8" bolts??
ok...somebody type reaaalll slow so maybe I can understand this approach to changing the stance of my car...it needs lowered just a bit...alot of space between tires and rear wheel wells.
8" bolts are the solution?
Tim
Old May 16, 2005 | 03:05 PM
SanDiegoPaul
Originally Posted by Timbo2
ok..
Tim
The spring is transversally mounted, and the arch is down when loaded normally. Tighten the bolts up to increase tension and RAISE the car, or install longer bolts to lower it.
Old May 16, 2005 | 06:13 PM
CrossedFlags77's Avatar
CrossedFlags77
Timbo2, here is a how to I wrote on lowering the rear. Its really easy to do.
Rear Lowering
I am just using the nylon lock nut and it hasn't come loose at all. I have adjusted the ride height multiple times with it also.
Old May 16, 2005 | 07:20 PM
1980 454's Avatar
1980 454
First nylocks can be backed off but not recommended to remove and reinstall twice and (DONT) use your impact on nylocs or they are garbage third there is no cotter pin holes becuase its a nyloc style bolt. I work with nylocs everyday and also have the same spring bolts as yourself i prefer nyloc they never loose grip . from what ive seen over the past 12 years. drilling holes in a nyloc style bolt thats new to me and wouldnt help any
Old May 16, 2005 | 08:15 PM
73jst4fun's Avatar
73jst4fun
I agree, I've used the nylocks for a long time and have never seen one back off...
Old May 16, 2005 | 09:58 PM
Timbo2's Avatar
Timbo2
Default installing rear springs
great write up...thanks for the tips (not bad for a young fella..i'm impressed)
Timbo2
To Installing rear spring bolts
