Starting Problems
Old May 16, 2005 | 11:18 PM
more_cc's's Avatar
more_cc's
Default Starting Problems
My 1980 C3 350 4sp is having starting problems.
The first time I try and start is from cold it takes about 20-30 turns of the engine and a good squeeze of gas to get her started. Once started she runs perfectly and even if I shut her down immediately and restart she starts first turn of the engine.
I have a feeling it's a problem with the carb, anyone else have an opinion?
Old May 17, 2005 | 01:45 AM
wombvette's Avatar
wombvette
That is THE most common problem with the Rochester carb. Most develope this symptom sooner or later. The fix is to rebuild the carb and pay close attention to the plugged wells on the underside. They are leaking and causing the fuel to leak down overnight. Until you get it fixed use this starting proceedure. First thing, cold, before you do anything else is to hit the gas pedal quick and hard about 10 times. Then turn the key and start it. This usually will get enough gas in there to start and keep it running until the bowls fill up.
Old May 17, 2005 | 02:12 AM
Kalway's Avatar
Kalway
Heh mine is starting to get like that... Good thing I already plan on replacing my carb in a week or so anyways!
womb is right about that technique, too. Of course mine only needs one good push on the pedal and a little tap once turning.
To Starting Problems
