Vacuum question.
Old May 17, 2005 | 11:07 AM
brooksman9's Avatar
brooksman9
St. Jude Contributor
Default Vacuum question.
I have noticed recently when I turn off the car that I hear a hiss from the front for just a second or two. Could this be a vacuum leak at the headlights? If it is could it be affecting performance during run time? If so what is the best way to trace it down. Thanks.
Also noticed while I was working on advancing dist yesterday that timing does not advance at all when vac advance is hooked back up. Is this normal? And I did replace the vac advance canister in the dist.
Old May 17, 2005 | 11:14 AM
kevinator80's Avatar
kevinator80
If your ac was on, you could be hearing the system equalizing after you shut down.
Old May 17, 2005 | 11:22 AM
brooksman9's Avatar
brooksman9
All the A/C components are gone. Thanks
Old May 17, 2005 | 12:37 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I'd say your hunch about a vacuum leak is correct.
Old May 17, 2005 | 03:32 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Yeah, but wouldn't the check valve prevent any engine running problems? or not? But I do think it is vacuum leak.
Old May 17, 2005 | 04:12 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
no the check valve works the other way.....any open hose or broken hose will just suck air....the check valve does not prevent this....what the check valve does is keep negative air pressure in the vacuum tank during WOT instances when the engine vacuum dips....
Old May 17, 2005 | 04:22 PM
fast idle's Avatar
fast idle
i would be more interested in getting my vaccum advance working properly,put in the lightest springs and regain some serious ponies.
Old May 17, 2005 | 06:01 PM
BigBlockk's Avatar
BigBlockk
Your advance won't move if you have it hooked up to ported vacuum.
BigBlockk
Later.....
Old May 17, 2005 | 06:25 PM
onaqwst's Avatar
onaqwst
iif my rockers and timing aren't set yet will that affect my brakes/booster.....meaning a spongy pedal?
b
Old May 17, 2005 | 06:46 PM
vabeachvette's Avatar
vabeachvette
Default Accumulator Tank
May be the accumulator tank leaking, had the same hiss on mine and that is what it was.
Old May 17, 2005 | 09:35 PM
Older Than Dirt's Avatar
Older Than Dirt
Patrick, it might be one of those badass Mississippi cottonmouths taken up residence.!!
Old May 17, 2005 | 11:26 PM
Jack71's Avatar
Jack71
The hiss could be coming from a faulty actuator relay. The aftermarket units tend to leak -- I went through two of them before I ponied up the money for an original piece.
It hissed for about 5 or 10 seconds until the vacuum was lost in the system.
Old May 18, 2005 | 08:03 AM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default Check your valves....sorta !
On my 72/350 this worked - Check the 3 relay vacuum switches (or 2 if 73 or later) that relay positive or negative vacuum to each headlight actuator or the wiper door actuator. They will still work even if they are suckng air in the most bottom seal. If they suck air in the bottom it can affect the mixture, especially at idle. Two are under the nose and one is under the passenger front fender. Mine leaked so bad that the engine idled so rich, it would carbon the plugs til it would not even run. I replaced all three - and it idles properly again. I still have a "leak down" after shut down near the vacuum tank, but have not isolated it yet.
Old May 18, 2005 | 11:24 AM
brooksman9's Avatar
brooksman9
BigBlockk
Later.....
I have it hooked to manifold vac per the instuction manual of the edelbrock 1406 carb (which is actually on my other car, but this one is a carter). I did recently put the lightest springs on and advanced the timing to 36 @2800. This did get rid of my off idle stumble. It will just barely spin the tires. Just faint enough to see that there are actually two black marks. My initial was then at 24*.Did not matter if advance was hooked up or not. I did back it back down to about 16* initial as it seemed to be knocking a little. I have not test driven it yet and won't get a chance to for a few days (d@mn work). I was thinking of getting one of those vac line replacement kits and just replace all the lines as I'm sure they are pretty old. One kit even came with actuator seals and a trouble shooting guide for a few extra bucks. Advance in dist is not stuck either. Moves freely.
Old May 18, 2005 | 03:27 PM
ruby76's Avatar
ruby76
I thought you were supposed to have "around" 16* initial timing, 20* mechanical by 2800rpm. 16* + 20* = 36* at 2800 rpm. Then the vacuum advance will add another 16 or so on top of that.
Old May 18, 2005 | 10:11 PM
bobs77vet's Avatar
bobs77vet
well thats not a bad goal.....my reality was a little different probably as a result of my ability level. i think mine came out to 20 + 16 + 13, last night we timed by buddies to 17 +19 + 18 ( base+centrifugal+vac)
Old May 19, 2005 | 08:56 AM
ruby76's Avatar
ruby76
Hey bobs77vet, did you ever see any MPG gains, or are you too busy putting your foot in the throttle!!!!
Old May 19, 2005 | 09:41 AM
bobs77vet's Avatar
bobs77vet
well maybe a little but not much, still getting about 12-14 MPH. i guess 330-340 hp kind of negates the OD capabiliites of the 700r4
To Vacuum question.
