bad noise coming from rear of car
1 Post
St. Jude Donor '07,'13
Here is a common problem we get at work allot - It’s the small "front differential mounting bushing". This small bushing tends to disintegrate with time. If it is worn out, there will be a noticeable pop / clunk each time you step on the gas and sometimes on the brake also. It is the whole front of the differential housing wiggling around from the torque you are sending to it at the front mounting point. My own car made the same noise you are describing straight as well as when turning. Hope this helps.
Sincerely,
Alan G.
Vette Brakes & Products, Inc.
ps - See VBP # 31040 - poly dif. mt. bsg. Kit or 31038 - rubber kit.
Sincerely,
Alan G.
Originally Posted by VBP
Here is a common problem we get at work allot - Its the small "front differential mounting bushing". This small bushing tends to disintegrate with time. If it is worn out, there will be a noticeable pop / clunk each time you step on the gas and sometimes on the brake also. It is the whole front of the differential housing wiggling around from the torque you are sending to it at the front mounting point. My own car made the same noise you are describing straight as well as when turning. Hope this helps.
Sincerely,
Alan G.
Sincerely,
Alan G.
