69 SB TH400 kickdown
Old May 18, 2005 | 11:51 AM
Ram Air Formula's Avatar
Ram Air Formula
Default 69 SB TH400 kickdown
its a late 69 SB with the th400 behind it. the carb and intake are not factory. its a weiland with a holley on top. there is not a kickdown bracket or swicth on the carb. there is a kickdown switch at the gas pedal though. Is this right? I always thought it was supposed to be at the carb? any idea on how I could wire up the pedal switch? I think it would help clean up the engine bay area. theres plenty of vacuum hoses and wires already under the hood.
thanks
Old May 18, 2005 | 11:56 AM
gerry72's Avatar
gerry72
On the pedal bracket is right. If you want it on the carb, you'll have to look at the other-than-Corvette (like the Camaro) applications.
Old May 18, 2005 | 12:23 PM
NHvette's Avatar
NHvette
Yup - switch at the pedal.
So, you are saying that the switch is currently disconnected ?
It's just a single wire that goes to the tranny.
How will it clean up the engine bay ?? confused.
In cowl induction hoods, this same switch controls the fresh air intake solenoid.
Old May 18, 2005 | 08:16 PM
Ram Air Formula
well i thought it would be on the carb. the info i had said it was, but i geuss it wasnt entirely right. so if it was supposed to be on the carb then moving it to the pedal would clean the motor area up some. not much, but some.
thats right about the cowl hoods. i had forgotten that.
thanks for the info guys.
oh does this kickdown wire go out through a hole right by the pedal by chance?
To 69 SB TH400 kickdown
