Front coil compressor tool tip....
Old May 19, 2005 | 11:03 PM
GDaina's Avatar
GDaina
does the nut wobble on the threaded rod? If yes, time for a new one
Old May 19, 2005 | 11:08 PM
glen242's Avatar
glen242
Originally Posted by gkull
I've never used a spring compressor on my 79 vette. Why would you?
You jack up the frame and put it on jack stands. Remove both front tires. Then you use a floor jack under the front A-Arm to hold it in place. Take the shocks out. Take the cotter keys out and nuts off the ball joints. Mine have never rusted so just a few whacks of a hammer and the spindle drops loose. Just lower the jack and lift the spring out.
I have the shorter 550# spring so I don't even pull the calipers off the rotors. If you have a longer front spring you might not have enough length on the brake hoses. So you might need to pull the calipers off and wire them back out of the way. It's a two person job about one hour. You could do it by yourself. Just make sure that the spring is centered and in the holding slot on the end. I also managed to strip out an lower A-Arm shock threaded hole using air tools so be careful.
Old May 20, 2005 | 10:58 AM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Well I have NO idea what my front spring poundage/length is, but I suspect it is pretty heavy duty (454 auto with A/C).
Dep
Old May 20, 2005 | 11:58 AM
Custum73's Avatar
Custum73
I too picked up a set of spring compressors similar to the ones pictured earlier (external spring compressors). The box said they could be used for compressing coil springs. Looking at them, I think that the a-arms are going to interfere with the threaded rod once I try to put the spring in. Can someone post a pic of how they set up theirs when putting the spring in? I'm out of town right now, but putting the springs in is the next thing I need to do when I get back into the garage.
Old May 20, 2005 | 01:48 PM
GDaina's Avatar
GDaina
The tool (external spring compressor) posted by Motownpace car is used to compress strut rods, will not work on coil springs. Do not confuse strut rod springs with coil springs.
