Fel Pro 1884r
Old May 19, 2005 | 12:10 AM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Default Fel Pro 1884r
The one piece pan gasket for big blocks, can you get buy without gasket sealers. on this install. Thanks Ron B.
Old May 19, 2005 | 12:16 AM
rosslato's Avatar
rosslato
just did this the other day. no sealer except the corners around timing cover and rear main, other than that keep it clean as a whistle. follow the recomended torque and pattern. awesome gasket
Old May 19, 2005 | 12:55 AM
itsonlyairandfuel
Thanks for your reply, torque spec,I hope is the same as a stock gasket. Now I've got to find the tightening sequence. next on my list is to figure out how to drop my centerlink assembly about a 1/2 inch to clear my nonstock 8 qt. pan. It never ends. Ron B.
Old May 19, 2005 | 05:02 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Old May 19, 2005 | 11:22 AM
rosslato's Avatar
rosslato
torque is 8ft lbs for side bolts and 18ft lbs for the ends. 1st snug em up, then for sequence start w/center bolt then do center on other side and then do X pattern till the sides done then do X pattern on the ends. 1st time u do it torque em to zero ft lbs then do the pattern again to 4lbs and again to 8lbs then toque the ends to 18
To Fel Pro 1884r
