Engine won't idle
Old May 19, 2005 | 01:13 AM
Double Aught's Avatar
Double Aught
Default Engine won't idle
This literally happened in a blink of an eye. I was coming back from the local 7-11, I was goosing it going up Mission Gorge Road, slightly over-reved the motor, slowed down to make a right turn and the engine died. I rolled to the stop sign and managed to start it. (Very hard starting) Got enough momentum to make it into my parking spot where it promptly died again. I once again got it started, after many pumps on the accelerator, but it won't idle. How does a carb go from working perfect to not wanting to hold an idle? Can anyone give me a starting point on what to look at to fix?
Old May 19, 2005 | 01:37 AM
rihwoods's Avatar
rihwoods
I would first try some carb cleaner. Some crud could have made it through your fuel filter. Any gas on your intake ?
Old May 19, 2005 | 01:56 AM
vette rod's Avatar
vette rod
Check the needle and seat could have some debris in it.
www.pugesekmotorsports.com
Old May 19, 2005 | 01:58 AM
Double Aught
Thanks for the replies. I'll try looking at it tomorrow in between coats of paint I'll be laying down.
Old May 19, 2005 | 07:23 AM
BigBlockk's Avatar
BigBlockk
You "slightly over revved it". Just how much is "slightly"? What sort of motor are we talking about? New, old, stock, hot rod?
What I'm getting at is you may have "slightly" bent some valves or jumped a tooth on a worn timing gear set or blown a head gasket or bent some pusher rods or broken some valve springs.
Hope not, but it's possible.
BigBlockk
Later.....
Old May 19, 2005 | 01:40 PM
Double Aught
BigBlockk
Later.....
It's a 396, slight cam upgrade, roller rockers and I may have clipped 6grand. No biggie. I missed the shift from 2 to 3. It is definately carb-related. No funky noises. Thanks.
Old May 19, 2005 | 01:47 PM
NHvette's Avatar
NHvette
Don't rule out timing, either. Maybe stuck advance or slipped/jumped distrubutor gear or hold-down.
Good Luck
Old May 19, 2005 | 02:01 PM
TJ76's Avatar
TJ76
Don't rule out a blown gasket... head, carb, intake!
TJ
Old May 19, 2005 | 03:30 PM
rihwoods's Avatar
rihwoods
Mission Gorge Road ??? How does "Old 80" sound...near Lake Jennings ??? If you floated the valves,I would think you would have heard that......think dirt in carb for now....
RW
Old May 19, 2005 | 03:38 PM
iNdigo's Avatar
iNdigo
I agree with NHvette, I think it's a jammed advance weight in the distributor.
Old May 19, 2005 | 04:05 PM
Double Aught
RW
Maybe it is a co-inkydink, but I filled her up the day before. Chevron too, but they may have gotten a delivery before I got there.
Old May 19, 2005 | 05:16 PM
69monzaredbigblock's Avatar
69monzaredbigblock
Had something similar happen to me. Turns out the tach drive gear broke and jammed the distributor main shaft. The distributor body turned so much the car died. Smoking gun was no tach operation when I cranked it over and over and over. Sure did flood it.
Old May 19, 2005 | 05:54 PM
rihwoods's Avatar
rihwoods
I use Chevron in the my Vette all the time....never had a problem but I change fuel filters yearly...I'm keeping fingers crossed that it is something simple:dirt, distributer.....
Keep us posted..
Old May 19, 2005 | 06:40 PM
Double Aught
Keep us posted..
To Engine won't idle
