wiper problems
Old May 19, 2005 | 04:40 PM
wbeck's Avatar
wbeck
7th Gear
Default wiper problems
I have a 69 with some subborn wipers. At present they won't shut off, even after both replacing and unplugging the switch. Any suggestions would be great. Thanks!
Old May 21, 2005 | 07:20 AM
68-427's Avatar
68-427
Hi
I can't tell you how to fix it, but I think the problem is the motor itself, it has a relay to return it to parked position after you cut off the switch, there is an override on 68's under the steering column, two vacuum overides and a switch between them to stop the wipers so you can change blades, I'd look first at the wiper motor, the relay may be able to be replaced separately.
Rog
Old May 21, 2005 | 07:36 AM
ffas23's Avatar
ffas23
I remember years ago someone having a problem like this because of a bad ground. You could hook up a test lead with two alligator clips and give it a try by cliping one end to the wiper motor and the other to a good ground or directly to the battery ground just to check to see if this is your problem.
To wiper problems
