Blinker Problem--PLEASE HELP!!!
Old May 20, 2005 | 10:31 PM
stroked75's Avatar
stroked75
Cruising
Default Blinker Problem--PLEASE HELP!!!
My 75 is having blinker problems, it seems the passenger side works fine -solid flash,nice and bright but the drivers side sometimes flashes and is very dim. Also the brake light on the drivers is very dim. I changed the flasher and checked the bulb but no luck. Can anyone help me or point me in the right direction. Thanks in advance.
Old May 20, 2005 | 10:39 PM
FeedVaal's Avatar
FeedVaal
It's almost always a poor ground connection. Take some emory cloth to the contacts in the sockets and trace the wiring to the ground point and clean it up.
Old May 20, 2005 | 10:44 PM
JustinGJ's Avatar
JustinGJ
I had a similar problem, my socket was faulty and the ground wire was broken inside it. As a temp. fix until I can get a new socket I slid a wire under the ground contact, then spliced it to the factory ground wire in the harness. Just to test it you could run a new ground slid into the socket to a good known ground, just to check.
Old May 20, 2005 | 11:23 PM
stroked75's Avatar
stroked75
Cruising
Thanks for the help!!! It was a bad ground. You hit the nail on the head. You guys are great. Thanks once again.
To Blinker Problem--PLEASE HELP!!!
