Should I be concerned
Old May 21, 2005 | 10:50 AM
phclub's Avatar
phclub
New England Events Coordinator
Default Should I be concerned
Today I was doing small work on the 70 vert and noticed a hieght difference from the left side of the car to the right. The distance between the wheel fender (dead center top) and the top of the tire on the passenger side is more than 1 inch greater than the drivers side.
Where should I begin to look to correct the problem. What points on the car can I measure to narrow down the cause of the difference?
Old May 21, 2005 | 11:08 AM
SkunkApe's Avatar
SkunkApe
Measure from the frame to the ground.
Sagging springs? Body alignment?
