Crazy Timing Issue!
Old May 21, 2005 | 09:16 PM
Nate '69's Avatar
Nate '69
Default Crazy Timing Issue!
I used 3 timing lights to make sure this was right. For best vacuum I have to set initial timing to 30 which is 17" vacuum. Any point below that drops the vacuum to 15" and below. No amount of tweaking the carb will let me get up to 17" without the initial 30 degrees of timing. This is at an idle RPM of 900 with nothing hooked up to vacuum except the gauge.
I know my harmonic balancer mark is accurate because I checked it when I had the heads off.
The vette is running like a turtle until 2800+ RPM. Do I forget about the initial timing and just make sure I only have about 32 degrees by 3000RPM?
Any clue what's going on? Why would I need so much initial advance with vortec heads?
355CID vortec heads/~9.7cr
Voodoo 268/276 (227/233 @ .50)
vortec performer intake
Holley 650dp
HEI
Old May 21, 2005 | 10:21 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
normally you don"t set timing to achieve the highest vacuum....you adjust the carb to achieve the highest vacuum. set the timing as close as you can to get 36* by 2500-3000 rpm and try to get 16*- 18* base timing at idle with the vacuum can disconnected. don't worry about the vacuum when setting timing.
Old May 22, 2005 | 09:05 AM
71redskin's Avatar
71redskin
Default timing
like bob said, just get yourself an adjustable advance timing like and and set up just like that
Old May 22, 2005 | 09:54 AM
Nate '69's Avatar
Nate '69
It seems like if all you do is advance the timing and get an increase in RPM and Vacuum then your engine is becoming more efficient with the advance and that would be a good thing. But 30 deg initial is quite a bit.
I know others that use timing to vacuum to tune but they end up with max at about 18 deg initial.
I guess at this point I'll set initial to ~18 and ~32 max in by 3000RPM.
Any more thoughts?
THX!
Old May 22, 2005 | 10:58 AM
BigBlockk's Avatar
BigBlockk
You could set the initial at 16 then hook the vacuum up to manifold to get about 30 degrees at idle. This won't drag the starter down on start up and as soon as you give it some throttle the timing will retard so it won't ping on ya. Once you get up to speed some centrifugal will be working for ya and when ya back off the throttle to cruise the vacuum advance will come back in.
Cool ain't it?
BigBlockk
Later.....
Old May 22, 2005 | 11:49 AM
Nate '69's Avatar
Nate '69
Cool ain't it?
BigBlockk
Later.....
That's the only thing I could think of too. Is there a reason this engine would want so much initial?
Old May 22, 2005 | 03:03 PM
BigBlockk's Avatar
BigBlockk
(1)The compression is a tad low for that camshaft.
(2)If this engine had old heads it would probably want even more advance. The heads you are using have a little more efficient combustion chamber than the original ones.
By the way, did you install the cam strait up or did you retard it. This will have an effect on advance lead.
BigBlockk
Later.....
Old May 22, 2005 | 05:53 PM
Nate '69's Avatar
Nate '69
I installed it straight up.
Should I advance it 4 degrees?
Old May 22, 2005 | 05:59 PM
Matt Gruber's Avatar
Matt Gruber
it(that cam) needs 3000 stall
Old May 23, 2005 | 02:10 AM
BigBlockk's Avatar
BigBlockk
That would help but the real fix is a new cam. Something with about 214 degrees duration would feel a lot better. What you need to do is get that intake valve closed a little earlier. This will keep more mixture inside the cylinder thus raising the effective compression ratio. With 9.7/1 compression your cam doesn't start to work until about 4000 rpm. Now if you had 11/1 compression this thing would suck your eyes in at 2000 rpm.
BigBlockk
Later.....
To Crazy Timing Issue!
