OK Here goes. Started new engine in 71 on sunday. Ran for 1/2 hour at 2000 rpms. The next day decided to set timing, adjust carb and thermo shoot the engine to check the new sending unit on the new heads. Started up, ran about 5 minutes started to hear a slight tick looked inside at the oil pressure gauge and noticed NO READING. Shut down engine and found dist. hold down bolt had vibrated loose enought to disengage from the oil pump drive shaft. Engine ran for I figure for about 5 minutes with no oil pressure! After ranting and punching walls for my stupid scew-up, reinstalled dist. set timing and oil pressure was reading 50 lbs. Did I just ruin my 3,000 brand new engine?
Hopefully you are wrong about the five minutes....with no oil pressure.....IMO,no choice but to pull head/pan for inspection. (The ticking may have been a lifter ???? ) Good luck....
OIL pressure at 50 lbs....somehow I doubt you ruined it....
if the dist was turning, engine running, I fail to see how in hell the oil pump could NOT be turning, as the dist is pulled down into the engine by gear action....that's the way in fact install them...drop it down to desired position, hit the starter to engage oil pump....
Did you "oil prime" the engine before start up ?
(Some put oil in thru spark plug openings,and some even lube oil pump gears).
Important to know if you caused "scuffing" of cylinder walls before you got oil pressure.That is the question...you at should least drain the oil and examine that...what temp was engine at when you noticed no oil pressure...??
Edit:remember:you ran the engine twice. So I assume you HAD oil pressure the first time....on Sunday....
my heart goes out for you...I've goofed just as badly or worse...you're only human. is there a simple way to check for bearing damage, cam lobe , ring.
If there is damage, whats the worst that can happen if you do nothing? premature failure? when will that reasonably be expected?
If you had the engine apart, could you tell if damage occured?
Whats the worst life experience you've ever had? how does this compare....(hopefully this IS the worst) try to put in perspective , such as this being part of the "learning curve" some of us have to pay more for than others.
Because of the way I drive mine, I might have to pull it and go back through it. If its too much, get rid of it. good luck, jim
I added the new cam start up lube to engine oil. Engine was assembled with engine assy lube and engine oil. Engine was primed with 1/2 drive drill on sunday. Squirted oil in all cyl. before start up. Lubed all rocker assy before first start up. I`m starting to feel a little better about this f up.
The oil pump was turning if the distributor was turning and keeping the engine running.
The problem you may have was that as the distributor rises up, you lose the seal around it, losing oil pressure, especially at the top end. You've probably noticed the oil flowing down the distributor shaft hole when priming with the standard priming shaft and drill.
The ticking was probably caused by lifets starved of oil. Be sure to check for a collapsed lifter once you get it together. If you still have 50psi, your bottom end and cam bearings are almost certainly ok.
BTW, I had something similar happen, twice! befor I discovered the hold down was damaged. No damage to my engine.
Gary
Great !!! Now the focus must be on the "five" minutes with "no oil pressure" on second start/run. I'm trying to understand the "five" minutes without oil pressure.
BTW:You can get an oil analysis for about $60 bucks or so just in case.Save your original filter,as you may want to cut it open....keep kool,dude.
Just thinking about this. The oil pressure gauge pick up point is in the top end of the block. It could have been just the seal on the dist. as gary said. Man this day has moved up from dismal this morning when I got to the office, to thanks to you guys, I think everthing gonna be allright outlook. I love this fourm !
I think, as others have said, it should be alright. The distributor is pulled down and will engage the oil pump shaft. The noise might have been a lifter. Since oil pressure is good, the bearings at least seem to be OK. I would lose too many nights sleep over it.
Gary was clever thinking of that one.(hard not being there seeing).So one can safely assume pump was turning but flow/pressure was reduced explaining "tick" which I think was a lifter.Think I would examine distirbuter shaft just for drill.....almost there....
Tonight I will pick up were I left off. Seting timing, adjusting carb and idle. last but not least putting the hood back on. Should be back on the road by Memorial Day. Thanks to all. Keep waving
No I shut it down the second I heard the tick. But I think it ran with the oil pump disengaged for 5 minutes.
Just an FYI to ease your mind. The oil pump doing it's job of pumping oil, has nothing to do with the distributor. It drives the disrtibutor. Even if the distributor is disengaged from the pump...the pump still pumps!
Whew...that's a tongue twister.
Eddie
Eddie
You have it backwards. The distributor is what drives the oil pump in a chevy small block. The distributor has a gear on the bottom that is driven by the gear on the camshaft. There is a groove cut into the oil pump shaft that engages with the slot on the bottom of the distributor.
