starter question, trans conversion
Old May 26, 2005 | 05:39 PM
jimbow's Avatar
jimbow
Default starter question, trans conversion
I'll soon be taking the automatic out of my 81 Vette, and installing a Muncie 4 speed. Will the starter I have work? ....in the same place or will it have to moved to the other side? (as one mechanic told me). Thanks in advance. Jim
Old May 26, 2005 | 06:04 PM
Jclgodale3's Avatar
Jclgodale3
I would suggest "never, ever use that mechanic". The other side? Of what? It will only need to be changed if you are changing the diameter of your flywheel...
Old May 26, 2005 | 10:38 PM
markdtn's Avatar
markdtn
Same side as before. I thought you did have to change the starter drive (or "Bendix") with a flywheel though. Might be wrong about that. Hollander lists a 780 for use manual transmission and an 818 with automatic but when you go to those applications, both are used with automatics and manuals. I would probably change it just to be safe.
Old May 27, 2005 | 01:09 PM
jimbow's Avatar
jimbow
APPRECIATE THE COME-BACK. Yea, that "mechanic" is really a parts remover at a junk yard....musta been snake-bit.
Ditto on changing the bendix. thanks again, jim
To starter question, trans conversion
