Help! Won't start!
Old May 27, 2005 | 02:57 PM
i885744's Avatar
i885744
Default Help! Won't start!
Hey all. I can't get my motor to start after doing some bottom end work. I"ve got an hei distributor. I replaced the module, the rotor is turning, if i take the cap off and jump the module it produces spark. I put a timing light on number 1 cylinder and it flashes as it should. I adjusted all my valves, I have pleanty of fuel going to it. What could be wrong? The only thing i can think of is maybee the coil? Its in time, i'm sure. It cranks and cranks and cranks with no hesitation, every once in a while it will fire 1 cylinder, but never catches. Any thoughts? Bad coil? Bad cap? Bad rotor? I get blue spark out of my number 1 plug wire, seems pretty strong.
Even if i retard the timing it doesn't fire at me.
Thanks, Mike Cook
Old May 27, 2005 | 03:06 PM
page62's Avatar
page62
Was the distributor removed? Did you correctly reinstall it?
Old May 27, 2005 | 03:27 PM
ltlevil's Avatar
ltlevil
I agree with page on checking the distributor, just because the plug is firing doesn't mean its in time. Also you said "bottom end work" don't know what you did but if the timing chain was off you did re-install it correctly I'm assuming. Sounds like distributor position to me though. I just put a Uni-Lite in mine and there is not much "slack" in it. Otherwords you don't have to move it much to adv. or retard it.
To Help! Won't start!
