Another starter issue
Old May 27, 2005 | 06:23 PM
Joebio's Avatar
Joebio
Default Another starter issue
Got mostly everything done, now the starter problem The problem is that the only starters that will fit my T5 bellhousing have a straight across bolt pattern, my block has a staggered bolt pattern.
Anyone ever drill and tap their block with it in the car????
Old May 27, 2005 | 06:32 PM
Sharky Guam's Avatar
Sharky Guam
No it is not wise to try to drill while the motor is in the car. This should be a precision hole to align the starter. So drilling a new hole in the block while it is in the car is not advisable. When we did our conversion, we found a starter that fit right in.......got ours at our NAPA store....
Old May 27, 2005 | 07:05 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you shpuld be abe to get a staggerd bolt starter without a problem
To Another starter issue
