TRW spring special installation and mods
I installed it in the car and the ride height is acceptable after special installation and mods. I am not recommending that anyone duplicate this, just providing FYI.
I installed the spring without the upper spacer ie. the fiberglass actually touches the differential cover. That saved an inch. I'm also using 8" bolts but was uncomfortable with how close the spring ends were to the sidewall so i cut the spring end shortening it by 3/4 inch.
The 330 pound spring is way way softer than my 5 leaf steel. The car acually squats when you goose it from a standing start. I'll let you all know how it works out for me in the long run.
I used factory shocks for a little while and it did seem softer with the fiberglass spring. It is totaly different with the better shocks. I would install them right away if I ever did another Vette.
-Mark.
I've heard of a more radical mod where you remove the rubber donuts from the crossmember and replace with 1/4" steel - this eliminiates the slop caused by the rubber bushings by attaching the crossmember directly to the frame and buys you about an inch and three quarters. Combined with a longer spring, you can get the rear down. (oh, and you need a spacer for the camber rods and you need to re-position the uppoer shock mount holes)
I haven't done this because it sounds like a royal PITA.
Anyone else heard of this?
I don't know much about the mod but it sounds interesting.
1. Place it in an open area away from any buildings.
2. Pour 1 gallon of gasoline over it.
3. Toss a match and run away like crazy.
4 Call VBP and order one of their springs.
Seriously, John Greenwood describes how to lower your rear end about 3/4" in the VIP article. However this does nothing to get your halfshafts back in the proper orientation. Your halfshafts should be level or slightly inclined at the center. 10" bolts aren't the solution either. You need a spring with the proper arch.
