OK the *official* non-OEM Seatbelt thread
I went the F-body route and they worked great. maybe I should think about selling my original 73 set. They need to be redone but would be good for someone looking for a NCRS car.seatbelt install
What about Pre '78? Mine is a '76 and the ones that were posted above are not correct.
One option is one of the belts from Schroth
http://www.schroth.com/english/container_english.htm
The big problem though is providing a properly reinforced center mounting location for the center-mounted shoulder strap.
Originally Posted by LI76
I'd love to do the F-body in my 76, but I had read it didn't work in a 76. How did you do it?
I'll get pics when I can, but my cam isn't very good. You simply remove the old seatbelts, grab your rear seat f-body belts, hog out the hole on the retractor some, I went to 5/8", and have the belts modified for the shoulder strap hanger on the B pillar. I took mine to an upholstry shop and they cut the belt at the floor mounting point, slid the latch off, removed the F-body shoulder strap guide and installed the Vette part. Then they reinstalled the latch and sewed the strap again, I only lost 3-4" max. I have plenty of room, but I'm only 5'11, 180lbs. There appears to be plenty of room to anybody that can fit in one of these cars anyways. I'll try to get some pics, but really there isn't much difference in looks from stock, just the updated latch style and ugly red button on the female end of the latch.
Thanks for the reply. You said use the "rear" f-body belts? I'm not having much luck on ebay finding the belts, but when I do, I look forward to seeing some pics if it's not a hassle! Thanks!
Finally got some pics taken of my F-body rear belt setup in my '76. Just for the non-believers out there, it is possible. Sorry about the mess, my battery is fubar'd so I have to keep the cables along.
I'm another 76 owner with the same seatbelt problem and the F-body solution looks great (thanks for the pics!). At the risk of sounding stupid, where do you buy the F-body belts and what year and model F-body rear belts work well for our sharks?
St. Jude Donor '05-'06
Originally Posted by fl_rider
#33
#35
seat belt fix
I am using the f body rear seat belts in a 1974, and yes they do work. I had to use the oem [corvette] latches however and it does not look quite right. The f body latches were on a real short piece of webbing and would not reach around the seat. The latching mechanism works okay, however the f body male part is just a little bit longer and sticks out of the female [corvette] latch. Just remember there is a seat belt guide for the f body car you have to cut off, and you will have to take the webbing out of the male f body buckle, so you can thread it through the hanger on the coupe. You do that by popping the cap off the buckle and gently prying [with two almost closed crescent wrenches]the body of the buckle to get to get the reatainer bar out of the buckle. Then you thread belt through hanger and bolt to floor underneath the seat. Re install latch. Most upholstery places i know will not sew webbing for seat belts because of liability. i would like to lengthen the webbing on the f body receivers, but local upholstery shops I know won't touch them. If anybody has any idea where I can get that done let me know.
#36
What I did on my 81 belts was buy a 50' roll of seatbelt webbing off ebay, cost me $16.50 shipped to my door. Replaced the webbing along with the original tags and took both assemblies to a local shoe shop and had them sew them just like the originals were sewn for $10. New belts for a total of $26.50 and you can't even tell I replaced them.
YBnormal...drive a vette
www.angelfire.com/al/swhite7/vette.html
#37
You just need to find a place that will sew them up, keep checking. I walked in, they sewed them up, I handed them a $10.00 bill, and left. No paper evidence, no harm done.
#38
Justin, I followed your advice and my 98 camaro rear seat belts just arrived today from an ebay seller. Looks like they'll work perfect, except they're grey. They were only 20 bucks and I couldn't find any black ones.
Anybody know if you can dye the nylon webbing black?
Thanks.
Thanks.
