I just received my new high torque starter yesterday. I got my car on the ramps tonight to take a look and I found my existing stock starter seems to have a "staggered" bolt pattern. My new starter does not have a "staggered" bolt pattern. Will this new starter still work? I looked under there and I believe there is another bolt in the block that is threaded. Is this where the second bolt goes?
I figured changing a starter should be a synch, two wires and two bolts. I figured I would do a quick check before I started ripping and tearing and get
So I figure I'll do a quick check here and start back again tomorrow. It's supposed to rain anyway.
The GM starters have a single bolt pattern so they only fit the flyweel they were designed to fit.
That aftermarket starter looks like it has 2 patterns and no nose cone. It will probably fit either big or small flywheel as it looks like it was designed to work on one in-line set of holes but both flywheel diameters. The lack of a nose cone means it should work with either size bellhousing as well.
-Mark.
I just got it installed and it works good. I do have one question.
When the car fires up I get a little bit of a whine, I know it's because the starter is still engaged while the motor's flywheel is spinning (faster than the starter). I don't believe it's hurting anything, there is no grinding when it's turning over, just the whine when I get "fire in the hole!"
Should I be concerned or not.
It's going to be nice to get rid of the heat soak. I'm hoping I can stop the car now when it's hot and come back a few minutes later and get it to start.
Let me know what you guys think.
I'm headed back out to change the oil while it's up on my ramps.
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
mr first profrom ministarter sounded like the mechanical fire siren on an old fire trucking winding down......
i sent it back and the new one they gave me sounds similar but not to any of the same extent maybe, like 10% of that noise....not really noticable unless you specifically know what you are hearing.....i'm assuming it has to do with the gearing....now i don't even here it when i start the car....
so if its really noticable you should swap it for another one, if only you can hear it but its not noticable/annoying, i wouldn't worry about it.
That noise sounds like the reduction gears winding down after the engine fires. Probably nothing to worry about but what do I know? I never use those mini starters to fix heat soak.
I usualy put the Ford relay in the starter circuit and forget about the heat soak problem. Either fix works but the mini-starter is preferred by many people especialy by those that like to "upgrade" the GM supplied parts. I think the Ford solenoid solution is more common with us old farts that never had mini starters back in the day. Cheap, effective and I usualy have a few used ones in a box out in the garage from my dad's old Mustang.
I wouldn't worry too much about the whine if it sounds like it is "coasting down". Probably the engine catches it and speeds it up a bit before it can retract fully...
