Ball joints from hell....
Old May 29, 2005 | 08:35 PM
73jst4fun's Avatar
73jst4fun
Default Ball joints from hell....
I thought this holiday weekend would be a good time to put in some new springs from VB & P that I had to lower the front end and replace the lower ball joints that were OEM with the rivets. No big deal right? wrong... those @#$%^& rivets....after I cut the heads off I used a center punch and then another punch and several hammers with no luck. Ended up using a angle cutter/cutting wheel to cut between the lower arm and the ball joint ear that was rusted over the years to the lower arm. The spring came out with no problem. Now I get to do the other side.....
BTW: the OEM spring weighed in at 12lbs. the VB & P spring (460) weighed in at 8.5 lbs.....
Old May 29, 2005 | 10:26 PM
75 Stingray!'s Avatar
75 Stingray!
Grind the head off center punch (one hit to locate drill) and drill the rivets out. A few taps on the on the ball joint stud should nock it out.
Old May 30, 2005 | 12:09 AM
rosslato's Avatar
rosslato
thats the way to do it jay
Old May 30, 2005 | 06:04 AM
73jst4fun's Avatar
73jst4fun
That's the route I followed, metal chisel off the heads, followed by grinding off and center punch and drill, still the body of the ball joint was rusted/fused/ maybe wedged from the factory to the lower arm, thought a few taps with several hammers/ air chisel would do it, wouldn't budge the suckers.... alittle soaking with BP over night and some more air hammering did the trick. Hey for 32 years they were in there so what's ever easy.. .. the spring was the easiest part, just pulled right out...
Old May 30, 2005 | 09:40 AM
mandm1200's Avatar
mandm1200
I tried doing it by grinding off the rivit. I didn't have a cold chisel. Tried knocking the rivit through. Noway was it coming out that way. Drilled the rivit and punched out what little remained. I had a heck of a time getting the steering knuckle to breake loose off the ball joints using a pickle fork, fork is a little shorter from all the hitting it took. I then picked up a tie rod puller before doing the passenger side. Put it on and a couple of turns of the wrench and the steering knuckle breaks loose. That cheap $5 tool was well worth it. Now if I only had a simple ,easy way to get the outer bushing sleeves out of the lower control my life would have been better.
Old May 30, 2005 | 06:49 PM
73jst4fun's Avatar
73jst4fun
Well the job is done, looks like the bolt in ball joints will be a piece of cake to remove and install. The 460 springs I installed from VB & P are fine although I cut them 1/3 of a coil,the height is at 27 1/2" to top of fender. I'll remove the springs and cut them down again, looking for the 27" height, just wondering how much more to cut off the coil springs at least the job now will be easy.........
To Ball joints from hell....
