seperating control valve/pitman arm
Please give me your tips.
I removed my control valve using the air hammer device. Easy as cutting through hot butter.
Use a puller.
This thread has several suggestions on removing the control valve including using a pitman arm puller, tie rod puller and pickle fork. To summarize:
Sounds like the pickel fork, hammer is a bad idea due to stressing the steering gear box.
The second tool mentioned was the Pitman arm puller. Can you use the Pitman arm puller to pull off the Control Valve? From one of the posts, it sounds like he is pulling off the pitman arm, not the Control Valve. Or is the idea to remove the Pitman arm which will then allow you to pull the CV off?
Third choice is a Tie rod puller which somebody mentioned as working ok if the steering wheel was turned al the way in one direction.
What is the best way to do this job?
Thanks for your help,
Hef
Hef
It depends on the design of the puller. There are clearance issues.
A tie rod puller may fit in the space for the valve, but not be robust enough to pull a pitman arm, but a pitman arm puller may be so bulky that you cannot fit it in the space to remove the valve ball-stud.
I have a "medium" sized OTC pitman arm puller that -just- fits in the space for the valve, and is also tough enough to pull the pitman arm. This particular puller also -just- fits between the upper & lower ball joint stud tips so it can be used to pop the ball joints loose. I also have the next size up OTC pitman arm puller, which will not fit in the required space to pull the valve stud, but can pull truck pitman arms.
It also depends on how tight the previous mechanic/owner tightened the nut on the valve ball stud. They do have a torque value, but most people seem to rely on the built in torque wrench in their arm. Since they are a tapered interference fit, when they're over-torqued, they can be extremely difficult to remove. So... a tool that works great on Johnny's Vette will not work on Suzy's Vette. Same holds true for tie rod ends & ball-joints.
Bottom line... you have to try one puller and go from there.
Edit: Since my particular OTC puller can be wiggled into the tight space above the control valve, I never have to remove the pitman arm to service the valve. The same OTC puller is a "pitman arm" puller.... so it can be used to pull the pitman arm as well.
Hef
http://www.otctools.com/frames-catalog2.php3
put in 7310
I have both 7310 ands 7311.
The 7311 fits above the valve and if used carefully will not rip the seal.
I put various metal artifacts between the tip of the main screw and the stud being wrestled with.... sometimes a (very) large nut on-end, sometimes a piece of metal stock cut-to-fit. Depends on the situation.
Double check the numbers..... the smaller one fits the valve.
I had them reversed.
Tom
That area is tight so I disconnected the tie rod and tapped twice and the PS control valve came free. No big deal.. Dave...
Thanks,
Hef
You have to match the size to the component you are working on.
You can buy them in sets, or individually.
They are also available for connection to an air hammer, as indicated above. This is a different type than the "normal" so it can be inserted into your air hammer.
IMOP, it's not a good idea to whack your steering gear box this way.
You can also install a harmonic balancer with a BFH.... it may not do damage that is immediately apparent, but in the long run it's a no-no. Same thing for a pickle fork and a gear box.
Jim Shea is a former GM/Saginaw engineer... I believe he also will say it's a bad idea to use a pickle fork. Maybe he's on vacation today.
Here is a quote from one of his posts...
"One other thing about using a pickle fork to remove a pitman arm from the steering gear. You can not only damage the pitman shaft seal, but you can also distort the gear housing in the seal area. This can cause even a new seal to leak around its outside sealing diameter and the gear housing bore."
Whether you bang on the adapter stud or the pitman/shaft.... the "whack" is transferred back to the gear box. For every action, there is an equal and opposite reaction.... just like my posts here on the forum. LOL
Will let you know how it works out, and I plan on documenting this for the next guy that has to do this.
Hef
