Clutch Linkage? See pics
Getting ready to pull this 4 spd tranny with the engine. See the clutch linkage here in the pics: What should be disconnected so that the tranny can come on out? Does that big arm disconnect from the base at the block? Looking for a nice and easy ride out.
http://www.photohost.org/gallery/sho...cat/500/page/1
Senior Member since 1492
Start by removing the vertical clutch rod. It connect the clutchfork & Z-bar. The clutchfork can remain in the tranny.
The big tube on the left is the Z-bar. Remove it from the block. You'll need to unbolt the other end of it which is attached to the frame via a bracket. Save all the peces. The Z-bar once disconnected from the frame bracket should just fall/pull right out leaving the stud still in the block.
Start by removing the horizontal clutch rod. It connect the clutchfork & Z-bar. The clutchfork can remain in the tranny.
Looks like you're missing the grease fitting for the Z-bar. (Hole in the bar)
http://www.parts123.com/parts123/yb....0050g~AAFDM~~~
Another piece I don't have. Thanks Gunther.
Never had the spring when I removed my linkage.
79vetter: don't forget to un-do the shifter, linkage and speedo cable.
That was just what I was going to ask: Where should the shifter and linkage be disconnected--closer to the actual shifter or at the transmission body itself?
I have the Z-bar and horizontal bar off but what about the connections underneath the actual shifter? I took off the shifter ball and T piece in the interior on the shifter--will the remaining "stick" just drop straight down when the rest of the tranny is unbolted or should I disconnect those shifting linkages underneath the shifter itself?
