header sidepipe question
Old May 31, 2005 | 11:39 PM
vette70's Avatar
vette70
Default header sidepipe question
Do you have to do any welding when you install headers and sidepipes or do they come ready to bolt on.
Old May 31, 2005 | 11:46 PM
Corey_68's Avatar
Corey_68
All you have to do is mont them, no welding needed.
Old May 31, 2005 | 11:47 PM
myoriginal77's Avatar
myoriginal77
The hookers are bolt on. Toughest part is the brackets that hold the sidepipes up. Also, expect to trim the rocker panels slightly near the front. If it's stick you have to remove the clutch linkage, it's a good time to replace the bushings and related parts. Most are available from Dr. Rebuild.
Frank
To header sidepipe question
