Will a '75 rad. core support work in a '72?
Old Jun 1, 2005 | 10:59 PM
singedfur's Avatar
singedfur
Default Will a '75 rad. core support work in a '72?
Will a '75 radiator core support fit in a '72? I hear a '75 is as big a support GM ever made (hence will allow the largest radiator).
Old Jun 1, 2005 | 11:55 PM
SkunkApe's Avatar
SkunkApe
No. Totally different animal.
Old Jun 2, 2005 | 07:59 AM
markdtn's Avatar
markdtn
Yes, I have a 76L-81 support in my 69.
Old Jun 2, 2005 | 08:33 AM
NHvette's Avatar
NHvette
The main difference is in where the weld-nuts are for cowl mounting.
All the holes are there, but the weld nuts may be missing ...
need to use bolt/nut combo.
There is no size difference that I know of.
Actually, SB 75 radiators are a thinner core than SB 70 ...
BB rads (I don't know) might be different.
Now - if you have a core support for a stock aluminum radiator ... all bets may be off.
But, yes - the 75 support will fit in the space.
If your support is OK - I would spend the $ on a new AL radiator.
Old Jun 2, 2005 | 10:34 AM
1971corvette's Avatar
1971corvette
I just installed a ( Be Cool ) aluminum radaitor ( part # 60029 I think ) behind a 1971 core support I will say this, Nothing bigger will fit in its place.I bought this off e-bay,I was told it came out of a vette race car. after spending 2 days making changes to the support, fabing brackets it still lacks just a little clearance on the neck so the hood will close all the way .I have 2 choices,have the neck of radaitor cut off and tig a small plate over where it should be,or notch the hood just a little more then it is from the factory.Looks like i will be doing a little fiberglass work this weekend.
as far as i see as to what makes a difference in what radaitor will work is the pieces of sheet metal on either side of the core support,the small block radaitor uses 2 block off pieces to close the size of the opening,the larger opening is used with A C,or big blocks is my guess.
Hope this helps
Old Jun 2, 2005 | 10:37 PM
singedfur's Avatar
singedfur
Thanks, everyone. Sounds like it'll physically fit, but I may need to use a bolt and nut combo where a weld nut may be missing.
So how/where do I get the skinny on just which support for which year/engine app was the largest?! I've heard the supports used for '75 were as large as they got. I'd like to be able to use the largest possible radiator.
Yes, I'll be buying a new alum. radiator for sure. I'm considering Be Cool and DeWitts. I've heard good about both but really don't know how to fairly compare radiators.
NHvette: Do you have a whole new rear skin on your car, or have you just stripped the back end? I'm considering a new rear skin for my car, and I'm curious to talk to someone who's done it.
Old Jun 2, 2005 | 11:36 PM
Mr.Gearhead's Avatar
Mr.Gearhead
I cut the top off my 1970 support and welded on a 1980 bottom piece. Got the 80' support for $25 b/c the thing took a front end hit... The weld nuts for the fan shroud were different
Old Jun 3, 2005 | 02:29 AM
ltlevil's Avatar
ltlevil
While you're shopping look at Griffin as well, thats what I have in mine. Two 1 1/8" rows keep mine at 172F at idle with only one elec. fan running not sure of the CFM. That is also with the trans cooler mounted in fron of the radiator.
To Will a '75 rad. core support work in a '72?
