composite vs steel rear spring
Old Jun 2, 2005 | 09:20 PM
cj7tenn's Avatar
cj7tenn
Default composite vs steel rear spring
I need to replace my rear spring. The composite spring I have now is cracked.
Composite springs never lose their tension, but can be damaged from road objects. Steel springs wont damage, but lose tension over time. A steel one is almost half the price of composite.
Any opinions on what is best way to go?
thanks
Old Jun 2, 2005 | 09:51 PM
62fuelie's Avatar
62fuelie
thanks
My 75 with composite spring rides a whole lot better than my 67 with steel spring.
Old Jun 2, 2005 | 11:55 PM
FeedVaal's Avatar
FeedVaal
If you want a softer ride, go with composite. If you want durability, go steel. I replaced my stock 9 leaf with the stock replacement but still needed a 9 inch bolt to retaiin stock ride height. I'll soon be replacing my stock rear end cover with a Muskegon HD unit and expect issues to arise.
Aftermarket parts are rarely identical to OEM, so expect some tweaking no matter which way you go.
Old Jun 3, 2005 | 07:40 AM
BerniesVette's Avatar
BerniesVette
I just rebuilt the entire rear suspension on my '79. My original 9 leaf rear spring still provides proper ride height so I stayed with it. If I were going to stiffen the suspension I would go with 550 pound front coils and a 7 leaf rear spring. I know the composites provide a very smooth ride but have heard too much about their cracking to use them. Just me.
Bernie
Old Jun 3, 2005 | 08:38 AM
Gordonm's Avatar
Gordonm
I have had my composite spring on for 7 years now and it has been fine. I run a 330# spring with no problems. I am running Bilsteins for shocks.
Old Jun 3, 2005 | 08:55 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Steel springs can also break. I snapped one before... I have used composite springs ever since! I also prefer the ride with the composite spring..
Old Jun 3, 2005 | 09:51 AM
Ganey's Avatar
Ganey
VB composite for less weight. No problems w/ mine.
Old Jun 3, 2005 | 09:55 AM
isosceles's Avatar
isosceles
what about exhaust heat? Olivier's running sidepipes. How about Ganey and Gordon? How close are your pipes to the spring?
Old Jun 3, 2005 | 10:08 AM
72-LT1's Avatar
72-LT1
I just finished replacing everything from the doors back, I went with the Muskegon HD rear cover and their stock steel spring. The ride height seems to be OK, I just moved it back and forth in the drive last night and the ride height seems to be at around 28.25" right now, I think it will settle a little after the alignment today and driving a while. This is all with the stock 6" bolts as well.
Old Jun 3, 2005 | 10:12 AM
Vesa's Avatar
Vesa
One reason why I stayed with steel 7-leaf (my clearance there is less than 1/3 inch...)
Old Jun 3, 2005 | 10:46 AM
rosslato's Avatar
rosslato
i've got the TRW spring w/ HD cover and bilstiens shocks. it rides great. i've had the spring for 12 yrs and no signs of cracks and i've put on a lot of miles. as for ride height i guess i'm wierd, i like the raked look and showing off my rear view
Old Jun 3, 2005 | 11:40 AM
Zimo's Avatar
Zimo
My car has a steel 7-leaf. Cool forum.
Old Jun 3, 2005 | 01:11 PM
theandies's Avatar
theandies
I wrapped my exhaust pipes with header wrap where the pipes go under the spring. Works great. You could also make heat shields or use aftermarket ones that came on the '82's (if they are still made).
Old Jun 3, 2005 | 01:28 PM
Mark70's Avatar
Mark70
I'm using a 7-leaf steel spring from Guldstrand Engineering. When talking to Dick, he recommened the 7-leaf steel with Bilstein sports over the composite spring. The spring from Guldstrand is also a little shorter and rounded off, so the spring ends don't interfere with wider wheels. So far I'm VERY happy with his recommendation.
-Mark
BTW.....Welcome to the Forum, Zimo!!
Old Jun 3, 2005 | 01:52 PM
jpatrick636's Avatar
jpatrick636
A good fabricator can run the pipes with proper clearance and as theandies said, header wrap works good.
I've never used anything but composite and never had a problem.
rosslato, man that's cleaner than my living room!
Old Jun 3, 2005 | 03:20 PM
camaroneil's Avatar
camaroneil
just ordered my vbp 330lb composite,
should be here in around 3 weeks so can't wait,
how much clearance should i allow for the exhaust,
neil
Old Jun 3, 2005 | 04:30 PM
73jst4fun's Avatar
73jst4fun
Went from the TRW composite 315 spring to the VB & P composite 340 spring, solved the height issue. Rides great with Bilstien shocks also. The steel spring weighs in at 45+_ lbs., the VB & P spring weighs in at 7.8 lbs. ....lots of unsprung weight removed......
To composite vs steel rear spring
Old Jun 3, 2005 | 04:46 PM
rosslato's Avatar
rosslato
thanx, it's cleaner than my living room also. it hasn't seen the light of day yet since i did it. next wk it will be on the road again, can't wait. i've done so many projects to it the last 3 1/2 months i've already forgot what a PITA they were.
Old Jun 3, 2005 | 06:41 PM
ETM's Avatar
ETM
From what I understand the Composite Spring weights only 8Lbs compared to the Steel Spring`s 44Lbs.I will probably do this mod in the near future.
I want to go with the 330Lbs spring but I have pretty stiff coils in the front with a huge anitsway bar.Will they work together well or will the car not ride correctly with the softer rear spring and competition in the front?
Old Jun 3, 2005 | 07:51 PM
skydaddy's Avatar
skydaddy
rosslato, that is awesummmm.
Mikey likes it.
I am in the process of a rear rebuild and just ordered a steel spring from VB&P. Ride height and all will come later as long as it doesnt change. I went with the steel for the durability problems that I had heard about, dont know if they are true but I figured why take a chance.
