por15 vs paint
Old Jun 3, 2005 | 06:40 PM
71redskin's Avatar
71redskin
Default por15 vs paint
i plan on redoing my engine and under carriage this fall/winter... i know por15 is better for the frame but is it also a better choice for the engine...opinions pleez
Old Jun 3, 2005 | 06:44 PM
iNdigo's Avatar
iNdigo
I don't think Por15 is suited for high temperature applications such as that. Go for a 500 degree Duplicolor rattle can, use their primer first, then whatever 500 degree color you want on top. I've had great success using this method.
the blonde weasel
Old Jun 3, 2005 | 06:45 PM
iNdigo's Avatar
iNdigo
oh... forgot to mention... the amount of time you spend degreasing and cleaning the surface (a good product is PPG DX-330) is directly proportional to how well the paint will stick and hold up.
cheers
Old Jun 3, 2005 | 06:48 PM
Z-man's Avatar
Z-man
Originally Posted by iNdigo
I don't think Por15 is suited for high temperature applications such as that...
Unless you use the POR-15 engine paint.
I might not be worth the expense. The amount required is not that much and the engine really doesn't get that hot. Many people say you can use regular paint, or standard high-temp paint if you are worried about the temp.
Old Jun 3, 2005 | 09:22 PM
norvalwilhelm's Avatar
norvalwilhelm
I used regular paint on mine 14 years ago and have no problems with it burning off. Engine temperature never exceeds the water temperature.
Old Jun 4, 2005 | 06:40 AM
78pacer's Avatar
78pacer
Of course it does.....what happens when a thermostat opens?
Old Jun 4, 2005 | 07:21 AM
71redskin's Avatar
71redskin
of course i was planning on using por15 engine paint, marine clean and possibly metal ready... is all that really a necessity or am i planning on doing more than is really required... thinking of doing my engine in red to match the car...
Old Jun 4, 2005 | 07:52 AM
raider21's Avatar
raider21
where can you get POR-15? and how much is it?
Old Jun 4, 2005 | 08:27 AM
stingr69's Avatar
stingr69
Try out the POR-15 first before you go and do a whole frame. POR-15 will peel off pretty easy off of clean smooth metal. If you were to use it where some of the part is rusty and some is still smooth, it can peel off the smooth parts and stick to the rusty parts. Just trying to give you an idea of how it works in practice.
Powder coat on the removable pieces is pretty nice. Regular paint with good prep works well. For the engine you can use high temp paint. JMO
-Mark.
Old Jun 4, 2005 | 08:32 AM
fl_rider's Avatar
fl_rider
Default Here is the link
http://www.por-outlet.com/
Old Jun 4, 2005 | 09:12 AM
raider21's Avatar
raider21
Default POR-15 link
Excellent!
thanks
Old Jun 4, 2005 | 09:49 PM
7d2 vette's Avatar
7d2 vette
i wire wheeled my hole frame 14 hrs worth in this frme is mint put on por -15 and it looks like it came from the factory and you cant scrape it off for nothin unless you put it over grease thats the only way, i even did the wheel wells you will need two quarts plus, i just did my exhaust manifolds in the por-15 cast paint they look awsome but the dam pint you got to buy i could do 50 of the dam things corvette central has good prices!!!1
Old Jun 5, 2005 | 01:40 AM
Z-man's Avatar
Z-man
I always get mine directly from them - no middle man. Pretty good speed in shipping.
http://www.por15.com/
Old Jun 5, 2005 | 10:16 AM
NHvette's Avatar
NHvette
I have always bought direct, too.
However, my local parts store now carries a small line of POR stuff.
Try calling around locally.
Degreaser is very important. Castrol superclean or simplegreen
will do just as well as marine clean.
The metal ready etchant can help adhesion on clean metal.
I would suggest: rather than metal ready - use "A Must for Rust" - at Home Depot. ...
it is essentially the same thing - Phosphoric acid to etch the surface.
Other products, too: Ospho, Naval Jelly, etc.
Old Jun 5, 2005 | 05:39 PM
kdlp's Avatar
kdlp
If you didn't know, POR-15 also has engine paint... it is intended to be brushed on (after the proper prep), but a buddy and I sprayed it on. There are very clear directions as to how thin you can dilute the paint and even at its thinnest ratio this stuff is thick!!!! The guy who sprayed mine had two guns/nozzles with him and said he really needed the bigger one he had left at home.
When it's cure it looks every bit as tough as the regular POR-15 and had great gloss. As I recall it's available in about 10 colors....
Check POR-15's web site for details on prep, etc.
I can't tell you how it lasts as I'm still reassembling my car after a body-off. But if it's as solid as the other POR-15 products I have no worries....
I have a couple of pics after the paint job, but don't have a host for them. Shoot me a PM if you want them.
kdlp
Old Jun 5, 2005 | 08:22 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
POR-15 Chevy Orange engine enamel brushed on the block.
Old Jun 6, 2005 | 03:26 AM
cv67's Avatar
cv67
St. Jude Donor '05
This is my latest motor done in POR-15 engine paint. Color is called Titanium. This paint rocks! Slick surface...You could pressure wash all day and it won't come off....
Did the entire chassis and underside of another ride I have in their regular POR-15. This paint is as tough as they say! Just take the time to prep it right. The result is worth it...
Stripped, sandblasted and metal prepped...Pic of the old 73 attached
Sprayed in makeshift booth
This was done 4 years ago and the paint looks exactly like it did when i sprayed it. I'm hardly ever here in C3, but if I can help with tips on this stff, pm me. I've made about every mistake you can make with this stuff. Had to sandblast the frame twice after wiping the frame down with lacquer thinner(not good)prior to painting the first time. This stuff is even hard to sandblast!!
To por15 vs paint
Old Jun 6, 2005 | 08:35 AM
72-LT1's Avatar
72-LT1
This was done 4 years ago and the paint looks exactly like it did when i sprayed it. I'm hardly ever here in C3, but if I can help with tips on this stff, pm me. I've made about every mistake you can make with this stuff. Had to sandblast the frame twice after wiping the frame down with lacquer thinner(not good)prior to painting the first time. This stuff is even hard to sandblast!![/QUOTE]
What should you wipe everything down with prior to painting? I though Lacquer thinner was OK?
Old Jun 6, 2005 | 09:15 AM
stepinup's Avatar
stepinup
What should you wipe everything down with prior to painting? I though Lacquer thinner was OK?[/QUOTE]
once blasted,as long as the medium you blasted with is clean,you should not clean what was blasted,just prime/seal.the degrease and dewaxer or whatever your using to clean will get into the pores and wont evaporate out will cause problems,especialy with exterior bc/cc systems,also when handeling metal panels after blasting use gloves,the oil from your hands will get in the pores and cause problems later,I wouldnt worry so much on a frame,but info is more for a exterior paint job
Old Jun 6, 2005 | 08:26 PM
cv67's Avatar
cv67
St. Jude Donor '05
POR 15 recommends rinsing it off after blasting, some marine clean wouldn't hurt.Paint on bare metal: I used no primer. You can let it air dry, even if it gets some flash rust its no problem. Their metal prep product is very good. Used it on the frame and most of the big pieces. Some of the smaller stuff I wiped down withacetone . Do NOT use lacquer thinner to wipe it down. It will cause the paint to react and you'll be doing it over. Ask me how I know The most important thing as an above post says is to make sure there is zero grease on the part. If you are blowing parts dry be sure to use a separator if you are using a gas compressor.
