I'm installing A/C on my 68 and I'm looking for the "add on" pulley that would work with my original pulley. My Assembly Manual doesn't seem to provide the guidance for a L79 with A/C and P.S.
I bought an add-on pulley (3751232) but it doesn't mate with my
deep-groove crank pulley(3858533)...it sits about 3/8" above the surface.
I found the below mentioned pulley at zip products, but I'm not sure if it's the correct animal.
That first add on pulley sounds like the one used on smog pump cars to run the A.I.R. system. I don't think the older cars had emissions controls so the one from ZIP might be right. Call their tech line and ask about it.
