electric radiator fan mounting help
Old Jun 5, 2005 | 10:54 PM
Mike Mercury's Avatar
Mike Mercury
Default electric radiator fan mounting help
I'm in the process of selecting an electric fan for the wifes 1973 small block.
I see there are a lot of choices for electric fans ($70 to $450 ); but I don't see any "easy" installation brackets offered for a C3.
Are those of you that switched over to electric - making your own mount/bracket; or modifying a commercially available mount?
I'd like to see some pics of mounting solutions if possible - along with the mfgr/model of the fan you chose.
Thanks.
(oh, and "puller" or "pusher")
Old Jun 5, 2005 | 11:11 PM
Mike Mercury
I found this pic:
I like that bracket. Is it home made ?
I found this thread as well; but not with much discussion about mounting:
http://forums.corvetteforum.com/show....php?t=1050293
Any help would be appreciated.
Old Jun 5, 2005 | 11:15 PM
Matt O's Avatar
Matt O
check out http://www.derale.com/main.shtml
Old Jun 6, 2005 | 06:31 AM
Cooter Tech's Avatar
Cooter Tech
I used Flex Lite dual fans 210-220 puller type. The fan comes with plastic brackets that bolt to the radiator support bracket after drilling 1/4 inch holes. The fan fits the radiator well and I have had no problems with it. You should use two relays with the fan.
Old Jun 6, 2005 | 07:43 AM
markdtn's Avatar
markdtn
I followed this one, but I have a 76L-81 core support which makes the bottom mount much easier.
http://www.idavette.net/hib/bbfh7.htm
Old Jun 6, 2005 | 07:57 AM
Hvymtlc5's Avatar
Hvymtlc5
I bought (2) 1 = inch wide X 36 pieces of aluminum flat stock from Lowes (about $7.00). Had a local welding shop weld them across the radiator ($15.00 and of course they cut off the excess). Bolted 2 electric fans to that. Easy and fast solution.
Old Jun 6, 2005 | 09:49 AM
Mike Mercury
just loving it guys.
Thanks much !
Old Jun 6, 2005 | 04:28 PM
Gordonm's Avatar
Gordonm
Originally Posted by Mike Mercury
I found this pic:
Hey that is my car! I got the fan from Dewits and the bracket was included. This could probably be done at home. It fits very nice and the fan is very solid. I'm having a little trouble with the sensor and location and temp setting but the fan is working good.
To electric radiator fan mounting help
