Rocker Panels
Old Jun 7, 2005 | 09:50 PM
Butch R's Avatar
Butch R
Default Rocker Panels
Hey Gang, does any body have any expereince in fitting rocker panels over hooker header side pipes,
I installed the pipes and know its time for the rocker panels, If youve done this you know what I'm talking about, is there a template out there to make the cutting and fitting easier
Thanks butch
Old Jun 7, 2005 | 11:46 PM
onaqwst's Avatar
onaqwst
i have a set that i can sell u cheap if u need a test set before cutting yours all up..... for a 77..... will they work?
b
Old Jun 8, 2005 | 10:09 PM
Butch R's Avatar
Butch R
Thanks for the offer of your rockers....... I have a spare set, just looking to make it easier on me
Butch
Old Jun 9, 2005 | 07:53 AM
Edzred72's Avatar
Edzred72
It's a custom cut & fit job. Too many variables between install & brands out there, so no templates or set instructions will work for all. Only advise I can give ya is to make a template out of cardboard for your application before you cut those expensive rockers. A dremmal tool works good for cutting and use lots of masking tape around the cut & during install to reduce scratches. Fine gage metal files for finishing the cut work good too.
Good Luck
Eddie
Old Jun 14, 2005 | 04:15 PM
Butch R's Avatar
Butch R
thanks Ed, I was hoping there was an easier way, I like your idea of a card board cut out to help with first cuts........ at least it's a base line.
I'm going on vacation soon and won't try to mount them untill I return,
so I'll let you know how I make out
Butch
Old Jun 14, 2005 | 04:20 PM
SteveG75's Avatar
SteveG75
There should be a template in the instructions. Be warned. I used it and my passenger side has a lot more clearance than my driver's side. Use the cardboard template.
To Rocker Panels
