Broke 3 wheel studs!
Old Jun 9, 2005 | 08:14 PM
CrossedFlags77's Avatar
CrossedFlags77
Default Broke 3 wheel studs!
I was driving home in my neighborhood and took a corner at about 20mph. I hear a popping noise and then a bad vibrate, get out to see that I have three wheel studs broken on the left rear. I hobble home since I was about 1/8 mile from my house.
I have been using wheel studs from Autozone and have always had problems with them seizing up or breaking. This has finally told me these wheel studs suck. Why does this keep happening, is it because I use 1/4'' spacers on the wheels?
Anyways...
What diameter are the knurls on the wheel studs I need. I am planning on buying some from Summit but I can't seem to find the right knurl diameter. I did a search and came up with .430 or .457" but Summit doesn't sell anything smaller than .480". What to do?
Old Jun 9, 2005 | 09:22 PM
Fastbackl48's Avatar
Fastbackl48
I have been itching to add cragar ss or torque thrust D rims to my 73' for years now. After tons of research I decided putting these aftermarket wheels on would be a bad idea. Too many horror stories with spacers. I did decide to go with the Torque-thrust II wheels since they do not require spacers. Just my .02 cents.
Old Jun 9, 2005 | 09:33 PM
litevette's Avatar
litevette
CrossedFlags77 - Hammer or press out one of you old studs and take it in to any performance parts supplier. They should be able to hook you up with some correct sized morroso's. They are much stronger than stock.
Fastbackl48 - If you order rims with the corect backspacing, you don't have to use spacers. A good tire & rim dealer can tell you what you need. You don't have to buy from them, just use their info.
Old Jun 9, 2005 | 09:37 PM
Twin_Turbo's Avatar
Twin_Turbo
Forget finding the right studs, get some larger ones like 1/2" and redrill the hubs for the new stud & knurl sizes (undersize of course)
Old Jun 9, 2005 | 09:39 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
you're very lucky. spacers are bad news. I did the same thing once but not quite as bad. When i went to take the wheel off 2 studs snapped off when i put about 2 foot pounds of torque on them.
spacers = death
Old Jun 9, 2005 | 09:55 PM
SkunkApe's Avatar
SkunkApe
spacers = death
Wrong (again...). Quality spacers are
Mr. Gasket cheapos = death (in some instances). A combination of cheap studs + cheap spacers = broken studs.
See: http://www.wheeladapter.com/ for quality spacers (@ $40/ea. )
Some good reading here, too: http://forums.corvetteforum.com/show....php?t=1106033
Old Jun 9, 2005 | 09:56 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
spacers = death
Yes -- the reason you are breaking studs is because those cheap crappy spacers just plain suck. They let the wheel become loose over time and that movement will cause stud failure.
1. Ditch the spacers.
2. Get the right size wheels if clearance is a problem, or move what is in the way of the wheel / tire.
3. Get good studs. I would bet that GM still has them in stock.
4. upgrade to the 1/2" studs if you plan on doing any serious racing. If not there are plenty of cars on the road that live fine with the stock studs.
Old Jun 9, 2005 | 09:59 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
all SPACERS = death.
Adapters - and they are different - are better. I am running VBP adapters for my wheels. There is no such thing as a "quality spacer". The web page even calls them adapters and not spacers.
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
spacers = death
I'm one of the few who like adapters (not the sandwhich style spacers)
Crossedflags, from what you say it sounds to me that you're using 1/4" spacers that move the rim off the axle's hub. I have to agree with turtlevette , these are junk = death....
A hubcentric adapter (or spacer) does not distribute any load on the studs while cornering...
Maybe your lug nuts were not tightened correctly which made it a lot worse...
I agree with TT, upgrading to 1/2" studs is a good idea - the original studs are 25+ years old anyway.... and yes, the AutoZone studs are trash, there is a lot you can buy there without problems - but there's also a lot of junk in these stores that shouldn't be sold to the public...
Old Jun 9, 2005 | 10:00 PM
turtlevette
skunk,
looks like we need to teach you the difference between spacers and adapters.
Old Jun 9, 2005 | 10:01 PM
SkunkApe's Avatar
SkunkApe
These should suffice: http://www.arp-bolts.com/
SkunkApe's Avatar
SkunkApe
skunk,
We're talking about spacers. We've been talking about spacers. Who mentioned adapters before your post?
Old Jun 9, 2005 | 10:03 PM
SkunkApe's Avatar
SkunkApe
They make custom spacers as well. Gotta read further than the first page. Send 'em an e-mail for your application and they send you a quote.
Old Jun 9, 2005 | 10:12 PM
redvetracr's Avatar
redvetracr
spacers = death
Gee, I have been using 1/2" spacers on my race car for 10 years without a problem.....Of course mine are solid aluminum NOT cast.
...redvetracr
Older Than Dirt's Avatar
Older Than Dirt
[QUOTE=litevette
Fastbackl48 - If you order rims with the corect backspacing, you don't have to use spacers. [/QUOTE]
I have to disagree with this statement. Backspacing and offset has nothing to do with caliper clearance. The design of the wheel itself determines whether or not it will clear the caliper. There is a measurement you can take off your rotor-hub-caliper to give the wheel manufacter to determine whether a wheel will fit.
Old Jun 9, 2005 | 10:21 PM
Older Than Dirt
I bought four of them from Fred. My life is worth more than 160 bucks. I installed long Moser studs also.
turtlevette
...redvetracr
i don't know why you have been lucky. Are they hub centric?
with non hub centric spacers the studs take the shear shock loading. Hitting a pot hole on the street can subject the studs to 50 - 100 K pounds of impact loading.
I ain't doing it again and i'm skeptical of adapters too.
Old Jun 10, 2005 | 12:07 AM
CrossedFlags77
The wheels and spacers were on the car from the very beginning when I bought the car. They have these on them...
So those seem to be the culprit. Does anyone know the knurled diameter of the stock wheel studs? I dont have time or the skills and I am sure my dad would flip if I told him I was going to redrill the holes to accept larger studs.
Oh yea by the way does anyone have a set of stock aluminum wheels they want to sell for cheap? Need true and straight wheels, doesnt matter if they look pretty cause I will paint them black.
To Broke 3 wheel studs!
